Hydraulic Cylinders
/ Hydraulic Cylinders #1
rchmielewski
Kubota L-3710
Anyone know of a source of hydraulic cylinders with 3/4" pin connections at each end for use with a Type I 3PH system. All of the cylinders I've seen have 1" pin connections.
/ Hydraulic Cylinders #2
Try Surplus Center in Lincoln, NE, sorry, but I don't have their telephone here at work. Another trick is to use bushings made for adapting smaller 3 point hitch pins to larger tractors.
/ Hydraulic Cylinders #3
Bob,
Northern Tool & Equipment shows a welded tee hydraulic cylinder that takes 1/2" pins.
Website: www.northerntool.com
Hope this helps.
Thomas..NH /w3tcompact/icons/wink.gif
/ Hydraulic Cylinders #4
The phone number for surplus Center in Lincoln, NE. is 402-474-4055
2009 EZ-GO GAS GOLF CART (A63276)
2009 EZ-GO GAS...
Hercules Gun Safe Holds 20 Guns (A65583)
Hercules Gun Safe...
IRRIGATION PIPE FITTINGS (A64276)
IRRIGATION PIPE...
121A (A63745)
121A (A63745)
2013 John Deere Hydraulic Grapple Tractor Attachment (A61572)
2013 John Deere...
2005 Peterbilt 379 Ext. Day Cab (A62613)
2005 Peterbilt 379...
