Hydraulic Cylinder Problem
   / Hydraulic Cylinder Problem #1
RamTruckMan
I bought a used three point backhoe. The backhoe is about 10 years old but was barely used. The seller said it was only used about 20 hours and hadn't been used the last six years. The paint is still inside parts of the bucket.
Anyway, the boom cylinder call be pulled in and out manually, however, it will not move in or out with the levers. I have loosened the hose connectors at the cylinder and both connectors will squirt fluid when the levers a pushed in or out. The cylinder does not leak. All other cylinders work ok.
What might be some of the causes of this problem?
   / Hydraulic Cylinder Problem #2
Can you swap the hoses from another valve to power that cylinder just to test it out under power?
   / Hydraulic Cylinder Problem #3
The piston seals may be bypassing...try this: Take on hose off, now operate the lever to energize the hose that you left on, it fluid shoots out of the other end of the cylinder then the seals are bad. It could also be that the valve has a PRV (pressure relief valve) for that function and it's stuck.
Thanks for the reply.
Yeah, I did that. Same thing, it will squirt fluid at the connection, if I loosen them a little bit, but the cylinder doesn't do anything, just limp. This cylinder is on the boom section, that the bucket is attached to and that section will swing back and forth, if I push it by hand.
   / Hydraulic Cylinder Problem #5
Well then, bad seals OR the Jesus nut that holds the piston onto the rod came off. Either way the cylinder needs to be removed and taken apart.
I see you are from Maryland to. I am in Cumberland. I will try that, to check the seals. Where would I look for the pressure relief value? The other thing that might be helpful is, that the hydraulic port at the far end of cylinder has a metal extension tube that runs along the cylinder down to the base of cylinder to connect the hydraulic hose. This tube will get warm when pressure is applied.
Thanks, I will do that. I will try and rigg up some kind of a gland wrench. On the other hand It will probably be the simplest to just take someplace and have them look at it.
   / Hydraulic Cylinder Problem #8
Post some pictures of the cylinder and valve if you can.
I took the cylinder off and there was no fluid in the cyclinder to drain out. Does that mean the cylinder could be air locked or some other problem. Fluid will squirt from the detached hoses when actuated. I have attached photo if that is helpful.
   / Hydraulic Cylinder Problem #10
RamTruckMan,
In your first post. you said the cyl did not leak. and that fluid would flow out the hose. Did you check the pressure on the system while operating the valve?
Put a gage on the work port and activate the valve momentary to see if the valve will go into relief and check the pressure. .
With the base end plugged, could you pull the rod out of the cyl?
2014 DRAGON PRODUCTS 130BBL VACUUM TRAILER (A53843)
2014 DRAGON...
2006 Imperial 14Ft Flatbed T/A Equipment Trailer (A50324)
2006 Imperial 14Ft...
2023 INTERNATIONAL MV607 21FT ROLLBACK (A54607)
2023 INTERNATIONAL...
Koyker Loader DoubleTine Bale Spear - Versatile for Round and Square Bales (A53473)
Koyker Loader...
(INOP) 2005 BRODERSON IC80-3G 9 TON ROUGH TERRAIN CRANE (A51406)
(INOP) 2005...
FUEL TANK/TOOLBOX COMBO (A53843)
FUEL TANK/TOOLBOX...
