hydraulic cylinder length.
   / hydraulic cylinder length. #1
jjbath
Northwest New Jersey
TC35
I mounted an 8ft Meyers plow to my tc35 recently. I bought it for $120 off of craigslbist. The QA plate was $110.
I mounted it to a QA plate but I wanted it as close to the tractor as I could get it with still being able to angle it. It didn't have pistons or even the mounts for them. Now I want to try adding power angle but it looks like there isn't enough room. It looks like I can get away with an 8inch stroke but I noticed the 8 and 10 have the same retracted length. That 2inches difference may be enough for it to work. The 10inch stroke and 8inch are 20.25inches.
Does anyone know if I can get a shorter one? If so any ideas where?
   / hydraulic cylinder length. #2
Surplus Center 9-7879 is a snow plow cylinder, 1 1/2" bore, 10" stroke, 17 1/4" retracted length.
I assume this is pin center to center not overall length.
   / hydraulic cylinder length. #4
Yes, pin center to center. I need a double acting cylinder. Not enough room for 2.
OH, snow plows normally use one single acting on each side.
Then check Surplus Center 9-4410-8 8" stroke 13 1/2" retracted.
Or 9-4410-10 10" stroke 15 1/2" retracted
2012 JOHN DEERE 644K WHEEL LOADER (A52705)
2012 JOHN DEERE...
1995 GMC CHIPPER/BUCKET TRUCK (A54607)
1995 GMC...
1999 WABASH 48X102 FLATBED TRAILER (A53843)
1999 WABASH 48X102...
2014 FREIGHTLINER  CASCADIA (INOPERABLE) (A53843)
2014 FREIGHTLINER...
RIGID 141 THREADER (A53843)
RIGID 141 THREADER...
2017 Nissan Frontier Ext. Cab Pickup Truck (A51692)
2017 Nissan...
