hydraulic cylinder length.
/ hydraulic cylinder length. #1
jjbath
Northwest New Jersey
TC35
I mounted an 8ft Meyers plow to my tc35 recently. I bought it for $120 off of craigslbist. The QA plate was $110.
I mounted it to a QA plate but I wanted it as close to the tractor as I could get it with still being able to angle it. It didn't have pistons or even the mounts for them. Now I want to try adding power angle but it looks like there isn't enough room. It looks like I can get away with an 8inch stroke but I noticed the 8 and 10 have the same retracted length. That 2inches difference may be enough for it to work. The 10inch stroke and 8inch are 20.25inches.
Does anyone know if I can get a shorter one? If so any ideas where?
/ hydraulic cylinder length. #2
Surplus Center 9-7879 is a snow plow cylinder, 1 1/2" bore, 10" stroke, 17 1/4" retracted length.
I assume this is pin center to center not overall length.
Yes, pin center to center. I need a double acting cylinder. Not enough room for 2.
/ hydraulic cylinder length. #4
OH, snow plows normally use one single acting on each side.
Then check Surplus Center 9-4410-8 8" stroke 13 1/2" retracted.
Or 9-4410-10 10" stroke 15 1/2" retracted
That would be perfect. I'll check it out.
Thanks.
2025 SDLANCH SDL2030GT Heavy-Duty Greenhouse Tent (A60352)
2025 SDLANCH...
iDrive TDS-2010H...
2017 PJ TRAILER 20' T/A TRAILER (A58214)
2017 PJ TRAILER...
2009 Blue Bird All American/ All Canadian School Bus (A61568)
2009 Blue Bird All...
Bobcat S740 (A57148)
2024 GMC Sierra 1500 Elevation Crew Cab 4x4 Pickup Truck (A60352)
2024 GMC Sierra...
