hydraulic cylinder length.
/ hydraulic cylinder length. #1
jjbath
Northwest New Jersey
TC35
I mounted an 8ft Meyers plow to my tc35 recently. I bought it for $120 off of craigslbist. The QA plate was $110.
I mounted it to a QA plate but I wanted it as close to the tractor as I could get it with still being able to angle it. It didn't have pistons or even the mounts for them. Now I want to try adding power angle but it looks like there isn't enough room. It looks like I can get away with an 8inch stroke but I noticed the 8 and 10 have the same retracted length. That 2inches difference may be enough for it to work. The 10inch stroke and 8inch are 20.25inches.
Does anyone know if I can get a shorter one? If so any ideas where?
/ hydraulic cylinder length. #2
Surplus Center 9-7879 is a snow plow cylinder, 1 1/2" bore, 10" stroke, 17 1/4" retracted length.
I assume this is pin center to center not overall length.
Yes, pin center to center. I need a double acting cylinder. Not enough room for 2.
/ hydraulic cylinder length. #4
OH, snow plows normally use one single acting on each side.
Then check Surplus Center 9-4410-8 8" stroke 13 1/2" retracted.
Or 9-4410-10 10" stroke 15 1/2" retracted
That would be perfect. I'll check it out.
Thanks.
2025 GPS Trailer (A56858)
2025 GPS Trailer...
WOOD GRABBER FOR MINI EXCAVATOR (A58214)
WOOD GRABBER FOR...
(INOP) 2012 INTERNATIONAL DURASTAR 4300 SBA TRUCK (A59823)
(INOP) 2012...
UNUSED KUBOTA 8 LUG WHEEL CENTER (A62130)
UNUSED KUBOTA 8...
2022 North Star Pressure Washer (A60352)
2022 North Star...
2019 Ram 3500 HD (A56435)
2019 Ram 3500 HD...
