Hydraulic cylinder aid?
   / Hydraulic cylinder aid? #1
YakkinEer913
'83 John Deere 650s
I took the cylinder to be repacked. When I got it home, I could barely open or close the cylinder manually. Now it's compressed too much to align it on my loader. What are some ways to pull it out without hurting it?
   / Hydraulic cylinder aid? #3
Be careful...moving the rod with the ports open can shoot oil with some force...!
best to connect to the hoses and extend normally...
   / Hydraulic cylinder aid? #4
Blow it with compressed air. It’s best if you have a hose on the other port going into a bucket to catch most of the oil.
   / Hydraulic cylinder aid? #5
I can't use hydraulics, there is no way to attach the cylinder to the machine so it just stays put. The pub can't go through the end of the cylinder locking it in place
   / Hydraulic cylinder aid? #7
One does not have to have hyd cylinder attached to implement to extend/retract rod when utilizing tractor hyd's to power cylinder. One can lay cylinder on shop floor or ground while extending/retracting rod.
I guess I was not giving it time to work it's way back into the cylinder. I've been fighting a Fuel leak so it doesn't run very long. I finally was able to get extension! Thanks for the help!
Thank you. I figured this out just before check-in here. If you can't tell, I'm new to this stuff. I've used this equipment for some time, but never worked on much.
2016 CATERPILLAR 336FL EXCAVATOR (A51246)
2016 CATERPILLAR...
2016 Big Tex 24ft. T/A Flatbed Trailer (A50322)
2016 Big Tex 24ft...
2018 FREIGHTLINER CASCADIA TANDEM AXLE DAY CAB (A53426)
2018 FREIGHTLINER...
2016 Ford Fusion Sedan (A50324)
2016 Ford Fusion...
2019 John Deere HPX615E Gator 4x4 Utility Cart (A51691)
2019 John Deere...
2016 FORD TRANSIT 250 VAN (A51406)
2016 FORD TRANSIT...
