Hydraulic Couplers
/ Hydraulic Couplers #1
TimberHole
Platinum Member
Missouri
JD9504WD w/ 75 Loader, JD345, Bobcat S150
Tell me about hydraulic couplers. I'm working on a JD 950 and the last leak to fix is at the rear couplers. They are Pioneer brand and I think I see a number of 050-2P. I don't know if these are the original couplers or replacements. Do I disassemble these and replace O-rings or buy new couplers? Recommendations?
And lastly, the dumbest question of all time.....do couplers require a thread sealant when installed? I found one coupler loose and thought I'd found my leak. After tightening I still seem to be dripping.
If replacement is the way to go, anyone have a recommendation for replacement?
Thanks.
/ Hydraulic Couplers #2
I would replace with Pioneer (same as what you have) and I use thread sealant if the fitting is NPT. Pioneer is a good brand and cost a couple dollars more but worth it. Or you can use Teflon tape as long as you back up about 2 threads before putting the tape on so as not to let it get into the hydraulic system. Some folks have good luck with rebuilding the connector but I just replace them. Most tractor places have them in stock.
/ Hydraulic Couplers #3
From my experience, the kind of couplers that use a ball on the end are likely to drip all the time because they don't use a rubber seal on the ball, just metal to metal. The type that use a plunger, or whatever they call it on the end have an O ring seal and won't leak there.
NPT threads need a sealant or they're likely to leak. I usually use Loctite 242 blue thread locker, because I have a large bottle and it serves both purposes.
/ Hydraulic Couplers #4
I splurged on a bottle of the special LocTite for hydraulic threads. It works well. Better than the liquid teflon tape.
3-gal. chemical inductor, Coal Valley, IL (A65640)
3-gal. chemical...
2007 FREIGHTLINER BUSINESS CLASS M2 SPREADER TRK (A64277)
2007 FREIGHTLINER...
2022 Greenworks CU400W Commercial Work Utility Vehicle DEMO UNIT (A63689)
2022 Greenworks...
2018 Kenworth T680 (A64127)
2018 Kenworth T680...
New/Unused ATS Welding Machine (A65583)
New/Unused ATS...
CATERPILLAR D9T CRAWLER DOZER (A64279)
CATERPILLAR D9T...
