Loader Hydraulic coupler seal
/ Hydraulic coupler seal #1
spox
I was re-attaching my loader on the b2630 when the o-ring inside the female coupler fell to the ground and disappeared! Does anyone know where I can get a replacement?
/ Hydraulic coupler seal #3
Be sure to obtian the exact o-ring because if you do not you will have a world of problems with hot hot oil.
I am unsure if it is an BSP O-ring British standard Pipe O-ring with the Blue Dot, but you must obtain the right o ring in any case any farm equipment dealer will have the right size o ring including the Kubota dealer you deal with.
It will be faster for you to call thier service department for the right size O ring if they are not within a reasonable driving distance.
leon
thanks guys... looks like i'm heading over to the dealer.
/ Hydraulic coupler seal #5
Hardware stores have o rings for all types of general uses.
Get rings from a dealer to make sure it is a ring made for hydraulics.
/ Hydraulic coupler seal #6
AS3209-015 or M83248/1-015 is the one that will fit. The ones at the hardware store will not. The dealer does not sell just that o-ring. Or at least mine didn't!!
Deano
/ Hydraulic coupler seal #8
You can also include hydraulic hose suppliers in your places to find the o-ring you need for a particular application, call around, lots of help using your phone. KennyV
Thanks all! The dealer said they dont sell the orings, that I would need to buy the whole coupler.
I'm going to try that online site... thanks!
/ Hydraulic coupler seal #11
They certainly do... including hydraulic uses...
I would go to the closest or most convenient place that had what I needed. KennyV
What I was refering to is that hardware stores sell all types of rings. They sell rings that are intended for a Delta fauset. Don't just match up the size. Use only rings designed for hydraulic fluids.
/ Hydraulic coupler seal #13
I had the same issue a few years back. I found an exact size match at Home Depot. A 10-pack of o rings was under $2.00. I'm not sure of the exact material composition, but it has worked fine for 2 seasons now. The FEL comes off every time I cut the grass. I figure if the replacement goes bad, I still have 9 left in the pack I bought.
2017 FORD F-350 XL 35' NON-INSULATED BUCKET TRK (A59823)
2017 FORD F-350 XL...
2006 Columbia Medical Transport Electric Utility Cart (A56859)
2006 Columbia...
2020 PETERBILT 567 (A58214)
2020 PETERBILT 567...
2008 JLG 600S TELESCOPIC BOOM LIFT (A62129)
2008 JLG 600S...
HYUNDAI HL955 WHEEL LOADER (A62129)
HYUNDAI HL955...
(INOP) 2018 BOMAG BMP8500 TRENCH COMPACTOR (A60429)
(INOP) 2018 BOMAG...
