Hydraulic Color Code
/ Hydraulic Color Code #1
linearxs
Northeast Ohio
Kubota BX2660
Hydraulic Color Code BX2660
Can anyone tell me the hydraulic color code for the BX2660. I went to hook up the hydraulics for my new front blade and on the tractor it is White/Blue/Red/Yellow but on the two cylinders it is Green/Orange/Blue/Red. I need to know what the color codes on the tractor represent. For example is BLUE the fluid supply for retracting the cylinder and RED the fluid supply for extending the cylinder?
Thanks
/ Hydraulic Color Code #2
From the BX2660 Manual
White = Forward
Blue = Right
Red = Left
Yellow = Backward
So, Blue and Red function together as inlet and outlet as the control lever is moved left and right. And, White and Yellow function together as inlet and outlet as the control handle is moved front to back.
Hope this helps...
/ Hydraulic Color Code #3
Just as important please remember that the
hydraulic system is double acting and WILL
have pressure on both sides AND be sure
relieve the pressure for the front end loader
with the engine off working the gimballed
control valve in all four directions.
_________________________________________________________________
Once you go flail you never go back:thumbsup::licking::drool:
/ Hydraulic Color Code #4
I have the front blade. the color code is yellow on tractor goes to blue on blade
red on tractor goes to orange on blade
blue on tractor goes to green on blade
white on tractor goes to red on blade
/ Hydraulic Color Code #5
Once I figured out the connections, I remarked the blade to match the tractor.
Take Care
Doug in SW IA
2013 PROFAB 200BBL CRUDE TANKER (A67714)
2013 PROFAB 200BBL...
JOHN DEERE 9420R ARTICULATING TRACTOR (A65057)
JOHN DEERE 9420R...
2014 FORD TRANSIT CONNECT VAN (A66091)
2014 FORD TRANSIT...
2023 JCB S3246E ELECTIC SCISSOR LIFT (A63276)
2023 JCB S3246E...
ALLMAND MAXI-LITE II V (A67714)
ALLMAND MAXI-LITE...
2025 SDLANCH IRET13 Electric Tricycle (A64194)
2025 SDLANCH...
