Hydraulic Chipper/Shredder Project
   / Hydraulic Chipper/Shredder Project #31
As far as I am concerned, I want it more for the chipper and to throw in a pumkin or something like that every now and then.
My leaf pile I use the roto tiller to mix it and it breaks down the leaves very quickly. The first pile of leaves I make from early in the fall season is almost broke down by the time I make the last pile in late fall. This is done so fast just by mixing it regularly with the tiller. One year when it was in the low 40s in december the pile was cooking away at 147 degrees ( I have a thermometer)
By the way that is the picture in my avatar with the steam coming off the pile.
As J_J mentioned, it appears to be only a shredder, not a chipper/shredder.
Having operated a shred only unit in my youth and I gotta tell you I would not proceed with the project. Burning fuel to shred leaves that will rot on their own with little labor on my part never made sense. My dad made me operate the unit for days on end each fall. Rake, haul, dump, pick up by hand, put in shredder, repeat.
I finally convinced him to push the leaves into a corner of the yard and let them rot into compost. I still do that in my yard to this day, only with a twist. I mow the leaves with my PT, which shreds them, and I TOW a Brinley lawn sweeper cart behind the PT as I go. The leaves get shredded AND picked up in the same motion. Then I dump them in a corner of my yard and use them in flower beds, garden, etc... as needed.
I don't mean to be a downer. If you have a use for the shredder, I think you have the perfect donor unit there. Low, low cost and should be easy to swap out the gas motor for a hydraulic motor.
I think your calculations are correct. You have to decide on the size of the motor and pulley. You might want to pose the question in the hydraulics forums as to if it is better to use gear up, gear down, or 1:1 on the motor and see if anyone can give you an advantage for either way to achieve the proper RPM of the shaft.
Hi David,
Thanks for the input. I thought about this quite a bit before deciding to proceed. I can't afford a big chipper shredder at this point in time, and the only thing available this cheap (i.e. $70) was the broken-down shredder. I did watch a YouTube video where someone with this exact model shredder-only was putting what appeared to be about 1" branches and such into it, and it absolutely shredded them. I calculate that perhaps 80% of everything I am pruning on my acreage is in that size range. If all it could do was leaves, I'd totally agree. However, it appears from everything I've read that this unit, properly powered, can do 1" branches and shrubs, weeds and such.
I think I'm going to modify my strategy. I'm going to go-ahead and spend the extra $25 and repair the engine, see how well it works, and if it meets the promise of being able to actually shred something close to 1" or more, then I'll look at doing a hydro-power project. If not, then I'll stop there.
Thanks so much you guys!
-Rob :)
Here's the video that convinced me this could work. This is the exact same shredder.
YouTube - MacKissic shredder attachment
I also agree with MossRoad that using such a unit for 'leaves only' seems really crazy. Personally, I keep a small push mower around for picking up leaves only. I just bag the leaves, and the mower does a very good job of picking up the leaves, cutting them a few times, then packing them into the collection bag. I usually follow the mower around with the PT, using the large bucket to allow me to dump the mower every few feet, since it fills up pretty quickly.
I actually bought a snapper riding mower that did a great job picking up leaves, but it died an ignominious death, with the gearbox grinding itself to death. Oh well. I donated it to the local repair shop for parts.
I also purchased a tow-behind lawn sweeper like MossRoad, but it only got used once a year, and seemed like quite a waste. PLUS, the lawn sweeper could not be 'disabled' when going over non-lawn areas, thus it just kept sweeping no matter where I towed it. Pretty annoying. I returned it to the place I bought it from in mint condition.
I know I'm off-topic, but the biggest problem on the property right now is WAY too much for the burn pile, and its all clippings, weeds, and little shrubs, with the occasional large branch thrown in.
-Rob :)
Jeez! Kinda like a blender with the lid off! :eek:
Yeah, pretty nuts, eh? It would help if he actually used the debris shield...
-Rob :)
   / Hydraulic Chipper/Shredder Project #36
-Rob :)
Yeah, I remember using our beast when I was a kid. It had a top load chute. I was feeding leaves into it and they got stuck. I used a rake handle to push them down. :eek: Looked just like those sticks. :p
Our shredder had two rotating lawnmower looking blades about 10" long stacked one over the other about 2" apart. They rotated parallel to the ground on the shaft of the vertical shaft engine. Leaves went in, mulch came out. It would fling them pretty darn far with quite a bit of force. You drop a rock in there and it had the potential to kill you with a head shot. :eek: Just like a lawnmower only two blades. Scary machine. Made by Sears! :)
It had a garbage bag attachment so you could mulch directly into garbage bags. However, you ever blow a coton ball into a jar? Can't do it. The thing would blow half the leaves back out at you. If you dropped a stick in there, it would blow a hole in the bag. You had to use "special" heavy duty Sears leaf mulcher bags. And if you filled them, you could not lift them. At least I couldn't. Overall, the machine was dangerous, scary and very good at shredding the $%^!! out of stuff. Tim Taylor would have been proud. :D
Yikes! That's a scary story. Sounds like you were preserved with all your limbs intact by the mercy of the Almighty. I'm surprised Sears didn't get sued big-time for such a contraption.
UPDATE: I was able to get the gas motor up and running after rebuilding the carb and rebuilding the ignition. Both were clogged/shot/shorted, etc. However, it is spitting flames out the muffler, leading me to believe that the exhaust valve is pretty shot. That's it, I'm giving up on this thing. I don't think its worth pulling it apart. Maybe I'm wrong.
I'm leaning towards buying a better platform (i.e. one that includes a chipper) if I am going to go to the expense and work of converting it to a PT Hydro-powered unit. Although the engine is on its last legs, I was able to run half a dozen branches (up to 3/4") into it, and it gobbled them up no-problem. It spit out tiny little mulch chips. Noisy, but very effective.
OK, I'll sit back and noodle on this some more. Nonetheless, it was fun to resurrect the engine, even though its pretty worn out. Reminded me of auto shop in High School.
Your input and comments are still solicited!
-Rob :)
   / Hydraulic Chipper/Shredder Project #38
Congratulations on gettting the engine going! These look like pretty amazing chippers.
Just to be a mild contrarian...given the expense of a PT and of a PT engine, would it be better to have this chipper on a Q/A plate, but self powered, so it could run unattended, and without the wear and tear on the PT?
Just a thought.
All the best,
Peter
   / Hydraulic Chipper/Shredder Project #39
Just a thought.
All the best,
Peter
You know, I think about that often... a self powered machine VS an attachment to the PT.
I guess we all have to identify our needs and uses and then determine if we would be better served by a machine with its own power source or by an attachment to the tractor.
Self powered allows you to use the tractor to bring stuff to the machine while it is running. A chipper/shredder and a log splitter come to mind. Another stand alone machine would be a generator, as when we have power outages, they are usually due to storm damage or snowfall, which I want to use the tractor to clean up.
However, the trade off is you have another engine to maintain. Personally, I want to have as few engines to maintain as possible. For instance, my firewood gathering... I bring it all home already cut into pieces and pile it up until splitting day. On splitting day I split and stack in the same place. No need to have a tractor available to move things around, so I could power the splitter from the PT as an attachment. If I had a chipper, I would probably gather all the stuff to be chipped into one pile, then chip it into my compost area directly, so I could power a chipper from the PT as an attachment as well.
Lots to consider for each person. :)
Hi guys,
The curiousity got the better of me, so I removed the cylinder head (surprisingly easy to do!) and took a look at what's going on in there. The valves move freely, and do seem to move up and down properly. They do not appear to be damaged. They were quite carboned-up, so I used some PB Blaster on it (Wow! That just melts the carbon!) and cleaned it all up. I then used the dremel tool with a little wire wheel and carefully cleaned off the carbon on the valve seats and the valves themselves. After all was pristine, I put it back together.
No joy. It's still spitting flames. My thoughts are that it is worn out, and the valve spring is not strong enough to keep the valve closed, so during the power stroke the hot gasses (with flames!) are leaking past the exhaust valve. At least in my mind that's what appears to be happening. Feel free to chime in...
So, I'm back to thinking about powering this thing hydraulically. Perhaps the least expensive thing to do is to put a non-variable control motor on it, with a proper relief valve. Couple of questions:
1) If I get an inline relief valve, how do you tie the bypass back to the return? Is there some kind of 'joining' device?
2) If I put in the variable control, then again, how do you tie the bypass back to the relief bypass and the return line?
I took "Fluid Mechanics" in High School and I think I understand how this stuff works, but I can't seem to locate stuff on the Surplus Center sight, or at least they assume that the reader knows exactly what they need and what it is called.
Thanks guys!
-Rob :)
Cat 936 936F 938G Forks (A59213)
Cat 936 936F 938G...
Komatsu WA250 (A55272)
WHISPERWATT 220 DIESEL POWERED GENERATOR (A58214)
WHISPERWATT 220...
12 X 20 CAR PORT (A58216)
12 X 20 CAR PORT...
GENIE S-60 MANLIFT (A58214)
GENIE S-60 MANLIFT...
2017 VOLVO VNM SINGLE AXLE DAY CAB (A59575)
2017 VOLVO VNM...
