Hydraulic bleeding valve location farmtrac 60
   / Hydraulic bleeding valve location farmtrac 60 #1
graciebullard
Farmtrac 60
I replaced hydraulic line going to cylinder on front end loader after finishing it will not move at all I don't know where bleeding valve is located on the tractor or the best way to go about getting air out
   / Hydraulic bleeding valve location farmtrac 60 #2
Just cycle the movement a bunch of times. Hold the lever till you see movement. After it's working well, check the hydraulic/transmission fluid with everything lowered to the ground, 3 pt and loader.
Hydraulic systems on a tractor very rarely need bleeding and the rare occasion it needs bleeding, is on the suction side of the pump.
Thank you very much for the input
2021 VERMEER S925TX STAND ON SKIDSTEER (A52709)
2021 VERMEER...
2023 Chevrolet 1500 Silverado Z71 Crew Cab Pick-Up Truck (A59230)
2023 Chevrolet...
CATERPILLAR 259D3 SKID STEER (A60429)
CATERPILLAR 259D3...
STORAGE FEES (A59904)
2024 CATERPILLAR 305 CR EXCAVATOR (A60429)
2024 CATERPILLAR...
5ft Rotary Brush Cutter Tractor Attachment (A59228)
5ft Rotary Brush...
