Hydraulic bleeding valve location farmtrac 60
   / Hydraulic bleeding valve location farmtrac 60 #1
graciebullard
Farmtrac 60
I replaced hydraulic line going to cylinder on front end loader after finishing it will not move at all I don't know where bleeding valve is located on the tractor or the best way to go about getting air out
   / Hydraulic bleeding valve location farmtrac 60 #2
Just cycle the movement a bunch of times. Hold the lever till you see movement. After it's working well, check the hydraulic/transmission fluid with everything lowered to the ground, 3 pt and loader.
Hydraulic systems on a tractor very rarely need bleeding and the rare occasion it needs bleeding, is on the suction side of the pump.
Thank you very much for the input
Honda EM3500S Portable Gasoline Generator (A59228)
Honda EM3500S...
HYDRAULIC THUMB CLAMP FOR MINI EXCAVATOR (A58214)
HYDRAULIC THUMB...
2023 Unverferth 3PT 10 FT Perfecta Field Cultivator (A56436)
2023 Unverferth...
UNUSED FUTURE 12" HYD AUGER (A52706)
UNUSED FUTURE 12"...
2015 UTILITY VS2RA 48FT REEFER TRAILER (A59575)
2015 UTILITY VS2RA...
Dump Truck Body with Tarp System (A55851)
Dump Truck Body...
