Hydraulic Arm Removal
/ Hydraulic Arm Removal #1
Whitey
Slippery Rock, Pennsylvania
Kabota B21 TLB
First thread, I hope this is right. I am the third owner of a used early 90s JD 770 with 7 backhoe and 70 loader. (My first compact) I am planning to do some maintanence work on it this winter speciffically the hydraulic cylinders. Some of the cylinders leak slightly on the backhoe. JD wants $ 50 + for a kit, and a local hydraulic repair shop will give me an estimate for free. Either way i am going to have to take the cylinders off. My question is, if I disengage the backhoe from the tractor and start to tear the backhoe apart, how do I releave the pressure in the hoses before dissconnection. Also, is there any opinions out there for doing all the cylinders or just the ones that are leaking.
Thanx.
/ Hydraulic Arm Removal #2
I would only do the problem ones. To releive the pressure you can depress the check ball on the quick release, or slowly loosen the lines with a rag wrapped around them. Or release the pressure while it's hooked up and the engine off.
Make sure the BH is NOT resting on the pressurized cylinders!! They are easy to rebuilt if you have a couple tools.
Good Luck,
Rob
/ Hydraulic Arm Removal #3
Machine is about 15 years old and some cylinders are leaking. The rest will leak by this time next year. Go to this site- Hercules Sealing Products and get your seal kits. The most expensive is $44 and the cheapest is $21. Take about half off as these are list prices. Hyd shop should be under $100 each to rebuild and test. These have the Vee style rod and piston seals which are easy to rebuild.
/ Hydraulic Arm Removal #4
disconnect the hoes.. but leve hoses connected to spool.. runt he spool around.. that should dump the pressure..
Soundguy
/ Hydraulic Arm Removal #5
Soundguy
Hey Soundguy, you letting your kid on the computer again?
/ Hydraulic Arm Removal #7
No kids.. but lots of cats... They like to set in my lap while I read email... lap is only big enough for about 2 cats.. and i got about 6x that many counting the barn cats. Usually have about 3-4 all walking across my desk vieing for lap time... Add to that I type fast.. like 90wpm... makes for plenty of spelling mistakes when you are looking at the side of a cat between you and the monitor and ya got another one rubbing it's face on your hand while trying to type.
I love em.. so I can't shoe em' away... What can i say.. I like most furry animals ( and some of the larger ones with horns or antlers with ketchup! )
Rick's right on too.. I'm having to set on one of those donut pillows :) ;)
Soundguy
/ Hydraulic Arm Removal #8
I can type 90 wpm to. Not sure what language they all are. So I guess if you take those out and the misspells, about 20.
Oh heck I can type 90 wpm. to to to to to to to to or a a a a a a a a a or how about " " That's space!! :D
/ Hydraulic Arm Removal #9
For those of us that actually remember having to take a typing class in school.. the word per minute count could also be done by character content.. not individual words.. etc. At least that's how our instructor did it.
Anyone else use the old original selectric's?
Soundguy
/ Hydraulic Arm Removal #11
Soundguy
You had the old selectric electric?
A step up from the stone age Underwood lever returns and individual keys I learned on.
I think mine had Barney Rubble's initials on it.
/ Hydraulic Arm Removal #12
I actually own a manual carriage return typwriter.. it's a bit of an antique.. but works.
And yes.. We used the selectric electric type's in school.. individual key arms.... At a job I used to work they had a selectric II with the uni-ball head..
soundguy
Hey guys thanks alot for the information I really appreciate the methods and the web sites. I am new to this but I certainly can see:D how benefecial this site can be for do-it-yourselfers! Sorry it took so long to reply.:D
2022 Magni TH5 5.19P (A63689)
2022 Magni TH5...
New 5400LB, Rachet Binders and G70 Chains (A62679)
New 5400LB, Rachet...
2004 GMC Sierra Pickup Truck, VIN # 1GTHK23U24F110736 (A65563)
2004 GMC Sierra...
Year: 2011 Make: Chevrolet Model: Express Vehicle Type: Van Mileage: 118,735 Plate: Body Type: 3 (A59230)
Year: 2011 Make...
Duratech HD 8 Tub Grinder (A62613)
Duratech HD 8 Tub...
LS XP8084 (A64126)
LS XP8084 (A64126)
