Hydraulic 3PH Links. Confused.
   / Hydraulic 3PH Links. Confused.
The three point hitch is a funny thing. Just for instance. Pulling a flail mower with floating attachment arms and a roller on the back, when the tractor front end dips the mower dips, exactly the opposite of what you would expect to happen. I had to build a model years ago to actually see this for myself. It was that extra pivot point that messed things up. I could not understand why when I crested the hill with the tractor, the mower would scalp the lawn.
The only tractor I know of with down pressure 3ph was the Belauris (sp?).
Usually, you just add weight to the implement for better ground engagement. I assume you don't have wheels on the rake.
I too have a thousand foot gravel driveway. My biggest issue is not spreading the valuable material off to the side. I have 69 Tonnes of stone dust sitting in piles in my driveway right now, and am too sick to go out and deal with them. I never had materal delivered with a tri-axle and didn't realize how high those things are when up. He dared not ry and spred the material on an uneven portion of driveway as the thing may start rocking and tip over!
   / Hydraulic 3PH Links. Confused. #12
I probably need to draw some kind of a vector force diagram; that is for a single blade, pushing back on it results in a ground force dependent on various angles etc.
Perhaps the reason the top tilt arrangement is so mysterious is that it depends on these various angles which differ greatly from installation to installation.
Thanks,
Mike
   / Hydraulic 3PH Links. Confused. #13
I am having some computer issues. Is there any spot in the forums for technical issues?
Thanks
This is the Forum: http://www.tractorbynet.com/forums/news-feedback/
[h=2]News/Feedback[/h]
Post any comments or questions, or report any problems with the forums here. Also includes news items relating to TractorByNet.com.
   / Hydraulic 3PH Links. Confused. #14
A hydraulic TL wont apply any more ground pressure than just lengthening the TL. There is nothing holding the lower arms down, they are free to float up. So, as you extend the hydraulic TL, instead of applying ground pressure, it raises the lower arms.
But, extending it does make it cut better, cause you get a better attack angle on the cutting edge of the blade
Is it possible that only the first SCV on a JD 6200 Tractor has float? I wanted to float the Harley, but found that I apparenty could not. There was apparently no detent on the second valve. I can't use the first, because I have a toggle switch atop that lever to control the electro-hydraulic valve on the Harley.
   / Hydraulic 3PH Links. Confused. #16
If your valve is a loader valve, then you probably have float.
What has the switch got to do with float. They are two separate functions.
You can also add float to a cyl .
Is the Harley on the front or back?
   / Hydraulic 3PH Links. Confused. #17
I am grading a 1/3 mi gravel driveway with a Kioti ck30hst and a 5' tilting blade and also can use a 5' box blade. I want to 'mound' the driveway in the center and make little drainage ditches on either side. I have done this somewhat with the 5' tilt blade, BUT there's not enough pressure on the blade to dig into the side ditch part...so,
Wil a top tilt hydraulic link enable me to put pressure on the grading blade so it will make a better ditch?
Seems it would be a little different with the box blade, would mostly tilt it forward or backward, not put too much down pressure on it?
Thanks
Mike
No, you won't get any down pressure with a hydraulic toplink... it just replaces the manual adjuster... so if you can't do it manually with the adjuster, you can't do it with the hydraulic version :)
Down pressure on a box blade is easy to add though... just throw some cinder blocks on the top.
I think there is a reason Kioti and other brands do not offer down pressure... I think outside of a PHD or similar implement, it offers less assistance than we imagine it would. For example, instead of giving you much better box blade functionality, you would simply unload the rear tires and spin out, or put all the tractive force on relatively tiny the front axle.
I am still having computer problems.
I spoke with the Service Manager at our selling dealer. I was very impressed that he knew immediately what I was talking about. Apparently it is not uncommon to not have float on addition SCVs.
Since I have a loader two SCVs and an electic valve spool for the loader grapple, I am out of stacking locations on the valve. Another SCV (with float) could have run 2Gs anyway, so that was not an option.
So, I thought my goose was cooked. BUT, what I will do, is merely change the control cables going to the valves, so my second lever has first valve with the float.
As far as what the switch has to do with float. As you can see in the pictures, I rigged up another loader style joystick handle on my SCV. Took some machining and clever work, but it runs a couple of relays and goes out to the receptacle into which I plug in my Harley three way valve. I never did get the control box with the harley, but with a hundred things happening at once when you are using this, this arrangement is really slick!
It is also a really good reason, to never be able to lend out the rake.
So I guess it takes me back to my original question. What to do if I want float but want that top link cylinder not to move on its own.
That, and how can I tilt this rake?
1995 Koehring LRT-110 7.5 Ton 4WD Rough Terrain Crane Truck (A55787)
1995 Koehring...
2015 FORD F-350 XL SUPER DUTY SERVICE TRUCK (A51406)
2015 FORD F-350 XL...
UNUSED WOLVERINE TCR-12-48H 48" HYD TRENCHER (A54757)
UNUSED WOLVERINE...
2015 Kubota RTV-X900 4x4 Utility Cart (A55787)
2015 Kubota...
UNUSED FUTURE FT15J EXCAVATOR (A54756)
UNUSED FUTURE...
UNUSED AGT YSRT14 STAND-ON SKID STEER (A52706)
UNUSED AGT YSRT14...
