hydraulic 3 point lift
   / hydraulic 3 point lift #1
daddyimp
Ford 850
Lift will not go up all the way, and when it goes as high as it will it surges up and down until I put another 200 lbs with a grader blade attached. Any one have any ideas. Thanks kenn
   / hydraulic 3 point lift #2
hi daddy
we need to know what the machine is, model, year etc.
simonmeridew
   / hydraulic 3 point lift #3
if this is his ford 850 from his profile, then there could be a few reasons.. but most will circle around his cam follower pin ( and or cam ) being worn down and needing repalced ( pin ) and built up ( cam ).. plus it will then need a linkage adjustment using the alternate method NOT using the nuday tools as outlined in the service manual.
I bet manipulating the draft lever makes the lift go to different heights too.
as for the bobbing.. that is usually leakdown and circuit regen thrut he unload valve. leaks are usually at piston seal to cyl.. though could be in cyl to top cover.. at safety/relief/check valves too.
I&T fo-20 manual will cover this repair fully...
soundguy
2008 Isuzu NPR-HD Landscape Dump Truck (A53422)
2008 Isuzu NPR-HD...
Econoline RA-48X24 Sand Blaster (A53117)
Econoline RA-48X24...
2014 MACK CXU DAY CAB (A54607)
2014 MACK CXU DAY...
2007 FORD F-750XL SUPER DUTY DUMP TRUCK (A51243)
2007 FORD F-750XL...
2020 RAM Promaster City Mini Van (A53117)
2020 RAM Promaster...
2011 Doonan 53' Trailer (A52377)
2011 Doonan 53'...
