hydraulic 3 point lift
   / hydraulic 3 point lift #1
daddyimp
Ford 850
Lift will not go up all the way, and when it goes as high as it will it surges up and down until I put another 200 lbs with a grader blade attached. Any one have any ideas. Thanks kenn
   / hydraulic 3 point lift #2
hi daddy
we need to know what the machine is, model, year etc.
simonmeridew
   / hydraulic 3 point lift #3
if this is his ford 850 from his profile, then there could be a few reasons.. but most will circle around his cam follower pin ( and or cam ) being worn down and needing repalced ( pin ) and built up ( cam ).. plus it will then need a linkage adjustment using the alternate method NOT using the nuday tools as outlined in the service manual.
I bet manipulating the draft lever makes the lift go to different heights too.
as for the bobbing.. that is usually leakdown and circuit regen thrut he unload valve. leaks are usually at piston seal to cyl.. though could be in cyl to top cover.. at safety/relief/check valves too.
I&T fo-20 manual will cover this repair fully...
soundguy
2018 Kia Soul Hatchback (A51694)
2018 Kia Soul...
2013 Cadillac ATS Sedan (A53424)
2013 Cadillac ATS...
1267 (A50490)
1267 (A50490)
2004 Ford E-350 Passenger Van (A51692)
2004 Ford E-350...
2019 ExMark S-Series 72in Zero Turn Mower (A51692)
2019 ExMark...
2016 Big Tex 14LX 14ft 7 Ton T/A Dump Trailer (A50322)
2016 Big Tex 14LX...
