hydralic oil vent
/ hydralic oil vent #1
benholt
millington tn
john deere 5420 and john deere 870
i have a 5420 john deere that blows hydrolic oil from a vent tube on top of my engine. why?
/ hydralic oil vent #2
Check your hyd pump shaft seal and you need to check the hyd oil level.
/ hydralic oil vent #3
:welcome:
Welcome to the forum from Northwest Alabama.
/ hydralic oil vent
Thanks for the reply but where is the pump and how do i get to it? Also the fluid level is o k . When it first started leaking from this vent tube i would have to operate it for 2 hours before it leaked and then i would replace the fluid. now it will leak 15 minutes after start up just idling. i also replaced the hydraulic screw on filter
/ hydralic oil vent
Thanks I'm from south west tennessee and do most of my own mechanic work but am stumped by hydraulic leak
/ hydralic oil vent #6
You could have a suction leak, therefore producing bubbles which will expand the fluid level and push fluid out the vent.
Look in the tank for any bubbles, and if any, look at your suction tube and fittings.
Heat will expand the fluid volume to a certain extent.
2001 Crosley 20FT T/A Flatbed Equipment Trailer (A59230)
2001 Crosley 20FT...
2014 Parker Trailer Sales Trailer (A60352)
2014 Parker...
2017 Peterbilt 320 T/A E-Z Pack 40Yd Front Loader Garbage Truck (A59230)
2017 Peterbilt 320...
2023 GREAT DANE FLP-0024-00053 53FT FLATBED TRAILER (A59905)
2023 GREAT DANE...
Preliminary Listing / Full Catalog Coming Soon! (A53317)
Preliminary...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
