hydralic oil vent
/ hydralic oil vent #1
benholt
millington tn
john deere 5420 and john deere 870
i have a 5420 john deere that blows hydrolic oil from a vent tube on top of my engine. why?
/ hydralic oil vent #2
Check your hyd pump shaft seal and you need to check the hyd oil level.
/ hydralic oil vent #3
:welcome:
Welcome to the forum from Northwest Alabama.
/ hydralic oil vent
Thanks for the reply but where is the pump and how do i get to it? Also the fluid level is o k . When it first started leaking from this vent tube i would have to operate it for 2 hours before it leaked and then i would replace the fluid. now it will leak 15 minutes after start up just idling. i also replaced the hydraulic screw on filter
/ hydralic oil vent
Thanks I'm from south west tennessee and do most of my own mechanic work but am stumped by hydraulic leak
/ hydralic oil vent #6
You could have a suction leak, therefore producing bubbles which will expand the fluid level and push fluid out the vent.
Look in the tank for any bubbles, and if any, look at your suction tube and fittings.
Heat will expand the fluid volume to a certain extent.
New/Unused 3-in-1 Quick Attach Frame (A65583)
New/Unused 3-in-1...
Adams 8 Ton Blender (A63688)
Adams 8 Ton...
IMPORTANT PLEASE READ!!!! TERMS AND CONDITIONS (A65583)
IMPORTANT PLEASE...
2018 22ft. Tycorp Vector Belt VB-16H (A60352)
2018 22ft. Tycorp...
2009 VOLVO VHD BOBTAIL VACUUM TRUCK (A63569)
2009 VOLVO VHD...
Bandit 200XP Wood Chipper (A63689)
Bandit 200XP Wood...
