hydralic oil leak
/ hydralic oil leak #1
tim1968
gasport new york
2001 new holland tc25d
my 2001 new holland tc25d is leaking oil down onto the mower deck. oil is coming out a hole that is between front and rear transmission drain plugs.hole is threaded but has no plug in it and i am able to stick a screwdriver into hole several inches, any suggestions? dealer wasnt much help
/ hydralic oil leak #2
is the hole in the dry area of the bellhousing.. aft of engine oil pan but ahead of trans pan? if so it could be a weep hole.. old fords had them.. was to leat oil escape the clutch housing if the rear main or tranny input shaft seals leaked.
it engine oil or utf fluid?
/ hydralic oil leak #4
tranny input shaft seal...
2011 Freightliner B2 School Bus (A61568)
2011 Freightliner...
2018 F550 Bucket Truck (A63689)
2018 F550 Bucket...
2018 CATERPILLAR 305E2 CR EXCAVATOR (A65053)
2018 CATERPILLAR...
FLAT BED (A65643)
FLAT BED (A65643)
2007 PETERBILT 386 (A65643)
2007 PETERBILT 386...
Massey Ferguson 9250 (A63688)
Massey Ferguson...
