Hydralic Fluid and Rubber Matts
   / Hydralic Fluid and Rubber Matts #1
colestin
Ashland, Oregon
Branson 3510
Okay, I have a leak. It's at one of the quick-connects with the loader control lever. I think I will need to remove most of the other connectors in order to tighten this one, so I won't be doing it right away. I try to keep a tin lid on the mat to protect it, but I bush-hogged the tin lid... anyway, the mat has sorta... swollen... in that area.
Should I just hit it with de-greaser and find a new tin lid until I fix the leak?
   / Hydralic Fluid and Rubber Matts #2
On my 2810 mine did the same thing.
   / Hydralic Fluid and Rubber Matts #3
More than anything else, the fluid will make the mat slick and cause you to slip going on and off the tractor, so be careful.
Many times, the leak is caused by an 'O' ring in the quick connect that is pinched or worn. This is a two minute fix, to pull out the old one and insert a new one. O rings are available at most hardware stores....
I had heard that the O-ring could not be replaced (you are right about the dinged-up o-ring). My dealer sent me a new quick connect, and I installed it. Torqued it as tight as I dared with my inadequate tools, and now it leaks from the threads. Next time I will replace the ring, now that I know that is possible. Thanks!
Yep! I doped the threads pretty good -- I thought. Maybe not good enough.
SHOP MADE MANIFOLD TRAILER (A52472)
SHOP MADE MANIFOLD...
2025 Kivel 48in Forks and Frame Skid Steer Attachment (A51691)
2025 Kivel 48in...
2025 25ft. 800Amp Extra HD Booster Cables (A51692)
2025 25ft. 800Amp...
2019 New Holland Workmaster 95 MFWD Compact Utility Tractor with 632TL Loader - Poultry Special (A52748)
2019 New Holland...
2020 Mathieu MC210 Azura Flex Street Sweeper (A51691)
2020 Mathieu MC210...
