Hydralic Fluid and Rubber Matts
   / Hydralic Fluid and Rubber Matts #1
colestin
Ashland, Oregon
Branson 3510
Okay, I have a leak. It's at one of the quick-connects with the loader control lever. I think I will need to remove most of the other connectors in order to tighten this one, so I won't be doing it right away. I try to keep a tin lid on the mat to protect it, but I bush-hogged the tin lid... anyway, the mat has sorta... swollen... in that area.
Should I just hit it with de-greaser and find a new tin lid until I fix the leak?
   / Hydralic Fluid and Rubber Matts #2
On my 2810 mine did the same thing.
   / Hydralic Fluid and Rubber Matts #3
More than anything else, the fluid will make the mat slick and cause you to slip going on and off the tractor, so be careful.
Many times, the leak is caused by an 'O' ring in the quick connect that is pinched or worn. This is a two minute fix, to pull out the old one and insert a new one. O rings are available at most hardware stores....
I had heard that the O-ring could not be replaced (you are right about the dinged-up o-ring). My dealer sent me a new quick connect, and I installed it. Torqued it as tight as I dared with my inadequate tools, and now it leaks from the threads. Next time I will replace the ring, now that I know that is possible. Thanks!
Yep! I doped the threads pretty good -- I thought. Maybe not good enough.
2019 INTERNATIONAL 4400 SBA 4X2 SERVICE TRUCK (A51406)
2019 INTERNATIONAL...
2015 Big Tex 70PI 15ft Pipe Top T/A Utility Trailer (A50322)
2015 Big Tex 70PI...
Guard Rail Pieces (A51692)
Guard Rail Pieces...
1994 Toyota 6000lbs 2 Stage Forklift (A52748)
1994 Toyota...
2006 Cadillac Escalade AWD SUV (A50324)
2006 Cadillac...
