hydralic couplers
/ hydralic couplers #1
carhartt56
Desoto , Mo.
KIOTI DK40SE
I havent used my fel since spring , and was in the barn last night and noticed corrosion on the hyd. couplers (male ends) on my fel . My question is , should they be ok with maybe just a clean up with some steel wool , or do I have more troubles to look at . I guess I wiped them off to well after I removed the fel this spring . The cat has had more seat time this summer than me with the drought here . Thanks in advance .
DK40SE
/ hydralic couplers #2
As long as you clean them up and there is nothing sharp you should be ok. The o-rings can seal pretty good.
CASE INTERNATIONAL 39 DISC HARROW (A64278)
CASE INTERNATIONAL...
2020 Freightliner CASCADIA 6X4 T/A SLEEPER TRUCK TRACTOR (A67148)
2020 Freightliner...
40ft 10 Door Shipping Container (A64194)
40ft 10 Door...
2024 CASE TV370B SKID STEER (A65053)
2024 CASE TV370B...
1991 Brenner 307 SS Single Comp Insulated T/A Chemical Tanker Trailer (A64194)
1991 Brenner 307...
2025 Unused SDLGC80 60v Electric Golf Cart (A64194)
2025 Unused...
