Hydaulic fill on L225?
/ Hydaulic fill on L225? #1
jlongpre
Kubota L225
Does any one out there know where to check my hydraulic level on a 70's L225? I just bought the tractor and have changed the oil and oil filter, fuel filter, greased all points on my FEL. I just can't figure out where to check my hydraulics, I've followed all my hoses, I must be missing something. Also are there any other tips for preventative maintenance?
/ Hydaulic fill on L225? #2
I have a 245dt that I believe to be similar. The hyd. and trans use and share the same fluid. On the left side of the trans near the clutch pedal will be a plug fitting. This is the fill level. Oil on my tractor is added up top by the gear shift lever. There is a mesh filter on my tractor to the back of the trans. This is under a plate secured by two bolts. Parts man would be your best friend. Messick used to provide a super service showing this stuff, but I believe they were required to remove this information.
MAC FLAMELESS HEATER (INOPERABLE) (A68842)
MAC FLAMELESS...
2018 CHEVROLET SILVERADO REGULAR CAB PICKUP TRUCK (A66091)
2018 CHEVROLET...
2014 Dodge Charger Sedan (A66738)
2014 Dodge Charger...
2019 John Deere 5100E (A64911)
2019 John Deere...
2007 KENWORTH W900 (A67714)
2007 KENWORTH W900...
SCAG TIGER MOWER (A64557)
SCAG TIGER MOWER...
