hyd. tongue swing for NH575/326 balers
   / hyd. tongue swing for NH575/326 balers #1
jimg
It appears the 326 doesn't have such an option but the 575 does. I wonder if the 575 kit will fit the 326 though. Any ideas? Any idea where the rear bracket attaches to the baler? Its not clear from the parts diagram. Any help would be appreciated.
   / hyd. tongue swing for NH575/326 balers #2
Buy 2-way cylinder, hoses of proper length and connectors.
Cut some 1/2" steel triangles for brackets.
Drill or burn holes in triangle for cylinder pins.
Weld on to tongue and frame to accomodate open and closed position. (Geometry 201).
Install cylinder and plumb to outlets.
Paint New Holland Red (Spray looks better than brush).
Work it.
Sit in chair and admire work.
Take pictures and load to TBN.
Done
Wanna see mine (in equivalent application) ?
Sure would
   / hyd. tongue swing for NH575/326 balers #4
Have at it. Extra points for using the entire cylinder length for swinging the tongue to its extreme angles.
Hints: Make a cardboard template of your fixture to "try out" the locations of the mounts. Also, go to a dealer having the kit and measure it up. BTW: You don't normally need a very big cylinder to swing that baby, but if you have some bale wagons on the back, that will increase the net tongue load...
   / hyd. tongue swing for NH575/326 balers #5
Well, if you can make anything out in these pics then good but this is the hydraulic setup on my 575
Not exactly what I had in mind...I was interested to see what you did. I know you have a diff baler but it would be interesting nonetheless. Ive looked several times at the parts blow-up at the CIH website. :)
Yup, I can, thanx!
VERMEER RTX 130 WALK BEHIND TRENCHER (A51242)
VERMEER RTX 130...
2006 International 9400i (A53473)
2006 International...
2014 Ag Spray Schaben Sidedresser (A53472)
2014 Ag Spray...
2005 Ford F-250 4x4 Reading Crane Service Truck (A51692)
2005 Ford F-250...
Kubota RTV-X1100C 4x4 Utility Cart (A51691)
Kubota RTV-X1100C...
2024 Bintelli ActivEV Pulse Electric Cart (A51694)
2024 Bintelli...
