hyd. tongue swing for NH575/326 balers
   / hyd. tongue swing for NH575/326 balers #1
jimg
It appears the 326 doesn't have such an option but the 575 does. I wonder if the 575 kit will fit the 326 though. Any ideas? Any idea where the rear bracket attaches to the baler? Its not clear from the parts diagram. Any help would be appreciated.
   / hyd. tongue swing for NH575/326 balers #2
Buy 2-way cylinder, hoses of proper length and connectors.
Cut some 1/2" steel triangles for brackets.
Drill or burn holes in triangle for cylinder pins.
Weld on to tongue and frame to accomodate open and closed position. (Geometry 201).
Install cylinder and plumb to outlets.
Paint New Holland Red (Spray looks better than brush).
Work it.
Sit in chair and admire work.
Take pictures and load to TBN.
Done
Wanna see mine (in equivalent application) ?
Sure would
   / hyd. tongue swing for NH575/326 balers #4
Have at it. Extra points for using the entire cylinder length for swinging the tongue to its extreme angles.
Hints: Make a cardboard template of your fixture to "try out" the locations of the mounts. Also, go to a dealer having the kit and measure it up. BTW: You don't normally need a very big cylinder to swing that baby, but if you have some bale wagons on the back, that will increase the net tongue load...
   / hyd. tongue swing for NH575/326 balers #5
Well, if you can make anything out in these pics then good but this is the hydraulic setup on my 575
Not exactly what I had in mind...I was interested to see what you did. I know you have a diff baler but it would be interesting nonetheless. Ive looked several times at the parts blow-up at the CIH website. :)
Yup, I can, thanx!
Michelin CARGOXBIB High Floatation Tires (SET OF 6) (A53473)
Michelin CARGOXBIB...
2014 CATERPILLAR TL642C TELESCOPIC FORKLIFT (A51246)
2014 CATERPILLAR...
378811 (A51573)
378811 (A51573)
2025 K5436 UNUSED (5) Wire Mesh Panels (A53117)
2025 K5436 UNUSED...
2015 International DuraStar 4300 Ambulance (A51692)
2015 International...
2025 CFG Industrial QK16R (A50123)
2025 CFG...
