Hyd Quick connects
/ Hyd Quick connects #1
chriswheeler
Platinum Member
Nevada
John Deere 970TLB,
Thinking about adding Hyd quick connects to my FEL lines. Does anyone know if they will slow down the speed of the FEL due to the restriction in the lines??? Think it would be handy to be able to remove the FEL every once and a while and the quick connects would make for a fast off and on. Thanks in advance,
Chris
/ Hyd Quick connects #2
There shouldn't be any difference in the flow, and yes, they would make it very easy to take the FEL off. I"m surprised they weren't already on there.
John
/ Hyd Quick connects #4
Can't imagine a FEL without them. Our FEL is off as much as it is on the rig. Add them , I don't think you'll be sorry that you did.
The tractor came to me from Tractor Masters in Sacramento. When delivered to my place in Nevada the dealer had mounted the Koyker 160 FEL. The dealer said that they don't normaly install the quick connects that come with the loaders because they restrict the flow and slow the loader down. I went back to the dealer anyway and got the quick connects and the bypass hose ( open center system ) anyway thinking some day they might be handy to have. Thinking when I drain the fluid and clean the filter next weekend, I will install the quick connects and see what happens. Dealer said most people never remove the loader from the tractor. I can see when changing a clutch, or some other repairs, being able to get the FEL off quickly without having a hyd fluid mess would have a advantage. Sounds like you all like quick connets, I'm going ahead and putting them on this weekend. Thanks,
Chris
/ Hyd Quick connects #6
</font><font color="blue" class="small">( The dealer said that they don't normaly install the quick connects that come with the loaders because they restrict the flow and slow the loader down. )</font>
I would file this away as a less-than-truthful statement meant to either cover-up his techs missing the step of their installation, or trying to save a couple bucks.
/ Hyd Quick connects #7
I agree with DocHeb. Quick disconnects are designed so that they do not restrict the fluid flow when the proper size hose is used. For future reference, I would be skeptical of anything that dealer said.
Think I'm a little skeptical already because of some other issues. Somewhat better than buying a car from a used car lot, they did provide some extra parts and stuff on later visits. The hyd quick connects came out of a 5 gallon bucket they seam to be collecting them in. Didn't try to charge for them either. They gave me the bypass hose, but I'm going to have to go fish for the fittings to make it all work. Lucky for me there is a tractor dealer a mile down the road from the house in Nevada. Still to be fair, I'm very happy with the tractor and implements I bought from them, got a great price and delivery 150 miles away. I knew I was buying a used 1977 tractor that would need some work sooner than a new one.
Chris
/ Hyd Quick connects #9
My Koyker goes on and off in 10 minutes. You will notice it should have come with the kick stands that hold up the loader when removed. There is a learning curve initially and the instructions are pretty good. I cut a lot of grass in the summer and can't imagine keeping the loader on because of added weight on the front, rougher ride and restricted manuvering. In my opinion this dealer is not very familiar with appropriate applications. Koyker sends the quick disconnects with their loaders and makes it apparent how user friendly they are. The only flow restriction is cerebral. You certainly have a very good loader!
/ Hyd Quick connects #10
Chriswheeler,
Sounds fishy that he did not charge for the couplers. They are not cheap. If he had a bucket full it sounds like they are not installing them to save time/money.
Try to keep the couplers clean. Aftre 4-5 years I have had to replace a few sets due to corrosion locking the quickconnects. My dealer gave me a free can of a penatrating oil to try to help keep them corrosion free. I'm still going to put something over the couplers as well as just USING the danged things every once in a while.
The rust in the couplers looks like it stared just from dust in the air and on the FEL from stuff falling on the couplers from time to time. Then the humidity in the air got into the dust.... At least that is my theory anyway.
My 4n1 bucket has never been removed from my FEL since it was installed. No reason to do so. Now that I have a pallet fork the bucket is removed often. I think this will help keeps things workng. I don't know how I lived without pallet forks... /forums/images/graemlins/grin.gif
Later,
Dan
/ Hyd Quick connects #11
Only down side to quick connects is they can leak. Don't know if mine were supplied by New Holland or the dealer, but they are pretty worthless. Get some good ones! Ask around and find a coupler brand with a good reputation.
/ Hyd Quick connects #12
Have_Blue I have noticed the same thing myself. The two Pioneer couplers that we mounted for the front grapple attachment both seep oil. I'm thinking of replacing them already to keep the mess on the pole barn floor to a minimum.
/ Hyd Quick connects #13
You need to get some Parker FC series no spill connect-under pressure they are the best Quick Connects. "IMO"
/ Hyd Quick connects #14
I reported the same problems with my QD sometime ago. I was told on TBN that they needed to be cleaned. That is not the problem. They leak because of the design and quality. /forums/images/graemlins/blush.gif
/ Hyd Quick connects #15
Ron maybe you and I both need to find some of those Parker quick connects.
/ Hyd Quick connects #16
Is it the FC connectors in general that are better or is it Parker FC in particular that is better than the other FC manufacturers? The reason I asked is it takes a lot of messing around to change hydraulic attachments on my tracked loader, even after releasing the residual pressure. I was thinking maybe one of the loader's connectors is damaged and trapping pressure within itself. If you're strong enough to get it about half way on, it goes on easiily the rest of the way.
/ Hyd Quick connects #17
Mike
I have solved the leak problem by installing a hose end QD with a plug in it. This has stopped all the leaks when there is not a hose attached.
/ Hyd Quick connects #18
Ron actually in our case it's the set of quick couplers that are forward and mate to the grapple.
They are the Pioneer brand purchased from TSC and tend to seep even when connected.
Really need to do something as they are making a mess in the pole barn on the concrete floor.
Thanks for all of your replies. I'm beginning to see why the dealer didn't install the quick connects. I have almost $25 in the 4 fittings to mount them to the hoses. The local tractor dealer, Smith Valley Garage in Nevada, had 3 of the 4 in stock at a great price. Had to wait to get back to Sacramento and buy the 4th from the parker dealer. Needed a 90 degree out of the pump to protect the coupler a little better. Have no idea what brand the quick connects are, they are the ones that Koyker would normally supply with the loader. Should have the last one on and get to refill the fluid and test this weekend after we return to NV. Yes the loader stands did come with it and are tucked into the frame right where they should be. Will take the loader off for the first time after the test. Thanks again,
Chris
/ Hyd Quick connects #20
Mike,
Try painting them orange /forums/images/graemlins/grin.gif /forums/images/graemlins/grin.gif /forums/images/graemlins/grin.gif. Seriously, I bought my quick couplers for my grapple from my dealer. I don't know what brand they are but I have no runs, drips or errors /forums/images/graemlins/laugh.gif.
Bill
2012 Freightliner Cascadia (A63118)
2012 Freightliner...
159119 (A60430)
159119 (A60430)
2025 Ligchine Spiderscreed Concrete Screed (A59228)
2025 Ligchine...
2014 VOLVO A40G WATER TRUCK (A62129)
2014 VOLVO A40G...
2019 FREIGHTLINER 126 SLEEPER TRUCK TRACTOR (A59910)
2019 FREIGHTLINER...
2017 Yale GLC050VX 3,500 lb LPG Forklift - Powershift, Aux Hydraulics (A63118)
2017 Yale GLC050VX...
