Backhoe Hyd question for BH experts- Woods 6500
   / Hyd question for BH experts- Woods 6500 #1
SteveV
MA
Bota 2400
The valves on my Woods 6500 BackHoe has three 'shock relief' assemblies, one set at 2400 and two set at 2100 psi. Does anyone know which functions require shock relief? I suspect that swing would be one of them- maybe the two 2100's but would have to trace the line for the other function. Since its like 15 out with the wind blowing, it might be better to ask.
The problem to make me ask is the behavior of the crowd function. The dipper stick seems to advance at seemingly half speed and I'm trying to decide where this oil is being relieved. Everything else seems to behave normally. The dipper has been grabbed by many a rock while being transported. Crowd would be on the extend side of the clyinder (most surface area)
Thanx for any help.
Steve
Thanx for the link, I was looking at my hardcopy to get as far as I did. Its good to know that is all available that easily.
Tracing the circuit will involve looking at the handle and watching which way the spool moves to activate what function, then following the line thru the bundle. Lots of chances for an error. I suppose I could loosen a fitting a squirt myself with oil to prove out the circuit the fast way. Then that is all dependent on the relief and the hose being attached on the same circuit on the end of the valve body (meaning no mystery passages in the valve body).
Steve
   / Hyd question for BH experts- Woods 6500 #4
Steve
Page 52 tells you everything you need to know about hose connections. That's why I provided the link.
NEW LandHero Mini Stand up Skid Steer (A53002)
NEW LandHero Mini...
2014 MACK PINNACLE (A52472)
2014 MACK PINNACLE...
IF YOU BID ON AN ITEM YOU MUST PAY FOR IT!! NO BACKING OUT AFTER IT IS SOLD!! (A50775)
IF YOU BID ON AN...
Ford Super Duty Pickup Truck Bed (A51691)
Ford Super Duty...
2000 John Deere 1860, 30ft Wide, Gandy Box, Wing Fold, 7.5in Spacing (A52748)
2000 John Deere...
1995 Rinker Captiva 190 (A52748)
1995 Rinker...
