hyd. pump replacement
/ hyd. pump replacement #1
ebeacham
Southport NC
TYM 723
Has anyone replaced their factory hydraulic pump with a higher output pump? Is this a bad idea?
/ hyd. pump replacement #2
Eric
I replaced one on my backhoe recently. I went from a 12 gpm to a 20gpm. There are advantages and disadvantages to adding a larger one. Advantages being-- everything is faster if you run it at your normal operating rpm, and you can usually run at a slower rpm . On the other hand, many of my hoe movements are more jerky and not as smooth as they were with the smaller pump. Operating pressures will be higher than before due to the increased flow and relief valves and cushion valves that may have been hardly used before maybe used constantly now. The only reason I went to a larger pump was because my old pump was worn out. A new factory was $958 and an after market was $600. The after market only came in a 20 gpm and rather than spend the extra, well you know. I only use the hoe for my property, but if I was using it commercially, I'd of bought the factory one.
If you want my 2 cents, I wouldn't get a bigger one. The tractor was engineered for that size (horsepower, gear ratio on pump) and might not behave like you want .
Gollum
Kioti LK3054 Tractor (A66285)
Kioti LK3054...
2014 Freightliner M2 106 Water Truck, VIN # 1FVACXDTXEHFU5910 (A65563)
2014 Freightliner...
Landhonor 24" Semi-Automatic Tire Changer (A62679)
Landhonor 24"...
2018 CATERPILLAR 573D FELLER BUNCHER (A62129)
2018 CATERPILLAR...
2007 BIG TEX 16 T/A UTILITY TRAILER (A65643)
2007 BIG TEX 16...
(4) 11R22.5 TIRES ON STEEL WHEELS (A64277)
(4) 11R22.5 TIRES...
