Hyd pump overhaul???
   / Hyd pump overhaul??? #1
horticattleman
South Central Louisiana
CT335
SInce my old 425 is now "new" the last thing I have to re-do is the hyd pump. Are there seals to change, how hard, ????????
   / Hyd pump overhaul??? #2
The first question is which pump? Mine has three:
1. Variable output drive pump with tram pedal control
2. Fixed output PTO pump with solenoid control
3. Fixed output Aux PTO pump that controls the lift, tilt, steering and Aux PTO functions
Overhauling 2 or 3 should be relatively straightforward and inexpensive. Overhauling #1 is much more complicated and expensive due to having a charge pump, swash plates, etc. Terry quoted me around $900 to rebuilt mine at Tazewell a few years back.
   / Hyd pump overhaul??? #3
What symptoms are you finding that drives the rebuild of the pumps?
2020 KENWORTH T680 TANDEM AXLE SLEEPER (A51219)
2020 KENWORTH T680...
2019 NEW HOLLAND TS6.130 TRACTOR (A51406)
2019 NEW HOLLAND...
2007 Reitnouer 40 Ton T/A Heavy Haul Flatbed Trailer (A49461)
2007 Reitnouer 40...
2019 PJ 25 T/A GOOSENECK TRAILER (A50854)
2019 PJ 25 T/A...
2013 Chevrolet Caprice Sedan (A50324)
2013 Chevrolet...
3000 Gallon Black Poly Water Tank (A49461)
3000 Gallon Black...
