HYD PRESSURE CAT1 VS CAT2
   / HYD PRESSURE CAT1 VS CAT2 #1
RoyKing
Platinum Member
Gainesville Florida
M7060HSC/18, RTV-X1100C
Read cat1 2500psi~
cat2 4000psi~
I've only read about one regulator for FEL and 2500psi~ is normal
   / HYD PRESSURE CAT1 VS CAT2 #2
   / HYD PRESSURE CAT1 VS CAT2 #3
To my knowledge Cat l or Cat ll refers to size of pins & dimensions between draft pins on a 3pt hitch but has no bearing on hyd pressures.
CAT 2 can lift 50% more weight so either larger cylinders or more pressure,
   / HYD PRESSURE CAT1 VS CAT2 #5
Every different model will have different lift capabilities.
The Cat 1 or 2 is sizing not lift capacities.
The lift capacity is determined more by sizing and linkage design, which will include pressure, linkage leverage and cylinder sizing.
IH 574 Cat 2, 3969 pound lift
IH 1066 Cat 2, 5600 pounds
CIH Puma 125 Cat 2, 12,185 to 15,197 pounds
   / HYD PRESSURE CAT1 VS CAT2 #6
As others have said... CAT 1-3 are 3pt hitch specifications. You can see them at TractorData.com - Three-Point Hitch. you accomplish the bigger lift capacities with bigger cylinders or different levers/gears in the system. Hydraulic pressure * cylinder size (in square inches) = cylinder force. Then that usually gets reduced a lot due to leverage & making the end of the 3pt move a lit more than the hydraulic cylinders.
Old tractors often ran under 2,000psi
Modern tractors generally run close to 2,500psi
Skid steers generally run closer to 3,000psi
Excavators are less consistent, but often run over 5,000psi.
   / HYD PRESSURE CAT1 VS CAT2 #7
x2
CAT0-3 are for the 3pt hit specs.
The hydraulics vary per machine.
Some of the newer excavators can run upwards of 6,000 psi (eg: some of the heavy Daewoo, Hitachi, and Hyundai units).
1993 HEIL TRAILER INTERNATIONAL FUEL TRANSPORT TRAILER (A52472)
1993 HEIL TRAILER...
2006 BOBCAT S130 SKID STEER (A52576)
2006 BOBCAT S130...
Toro Mower (A50324)
Toro Mower (A50324)
2015 GMC SIERRA 2500 SERVICE TRUCK (A52576)
2015 GMC SIERRA...
2007 TRANSCRAFT 48X102 FLATBED (A52472)
2007 TRANSCRAFT...
2010 Honda CR-V SUV (A51694)
2010 Honda CR-V...
