Hyd. oil capacity
/ Hyd. oil capacity #1
dieselsmith
Bronze Member
NW PA
Kubota L 2800 HST
I have a L2800 and the added oil capacity upgrade was done. Does anyone know how much oil this thing will hold now? I am sure other folks have done their 50 hr. service and have it figured to the drop! I need to know how much I need with a filter change. Also, I don't want to start a big debate but- UDT or SUPER UDT? Thanks fellas!
/ Hyd. oil capacity #2
You have an HST, I believe that Kubota specifies Super UDT for your tractor. I'm not sure of the quantity that you need, however, a phone call to your local Kubota dealer should yield that information because they probably do a lot of fluid changes on the L2800.
Jim
/ Hyd. oil capacity #3
When I did my service on my B-7800, the dealer gave my wife UDT which I had her return for the Super UDT. I think the price difference for 6 gallon of fluid was only $30. I think I would stick with Super UDT, but just my opinion.
As far as the amount that it holds, my book was pretty close to being exact. Of course it depends on how well the fluid drained out.
/ Hyd. oil capacity
I have the info on what it holds stock but I have the additional oil capacity upgrade to quiet the over run clutch clatter. That is why I have a dipstick on the center hump of the floor. Tractors without the upgrade don't have the dipstick. The dealer did not even know the capacity or about the upgrade even though they did the work! I talked with another dealer and they said regular UDT is just fine to use and not spend the extra unless there is alot of winter use.
PENDING SELLER CONFIRMATION  READ BEFORE BIDDING (A61306)
PENDING SELLER...
2020 Takeuchi TL8R2 Track Loader with 72in Tooth Bucket (A61306)
2020 Takeuchi...
(100) UNUSED KJ K0311-10' GALVALUNE CORRUGATED (A60432)
(100) UNUSED KJ...
2025 CFG Industrial QK18R Mini Excavator (A59228)
2025 CFG...
2022 RAM 2500 HEAVY DUTY (A55745)
2022 RAM 2500...
2025 CFG Industrial NT20-CZ Mini Excavator (A59228)
2025 CFG...
