Hyd hook up
/ Hyd hook up #1
sokoj
To JJ and kend. If I run a hose from the outlet port of the FEL control to the inlet port of the log splitter control(LSC) and then run a hose from the out let port of the LSC and connect it to the hose removed from the FEL control, will it work. I would adjust the pressure relief on the LSC if it has one to around 1700 PSI as that is what most snow plows operate on .
/ Hyd hook up #2
Yes it will work, if it is an open center valve. If that valve is a used valve, you really don't know if the work ports are not leaking, and if it will lift and maintain the blade height. If it drifts down at 30 mph, I think it will get your attention. Are you trying to adjust both the angle and tilt?
/ Hyd hook up
To JJ. Will only us the LSC for left and right angle of plow. It is mounted in the bucket of my Kioti. I assume my FEL contrrol will still work for raise and lower of the plow also. Am I correct ??
/ Hyd hook up #4
Yes. The FEL will have priority over the other valve. If you are not using the FEL, you can operate the plow.
/ Hyd hook up
Thanks JJ and kend. Will send pictures when complete. Weather here nice now but better get off my duff and start on this project soon or I will be doing it in the cold rain,sleet or snow ! Thanks
46901SFL (A64557)
46901SFL (A64557)
PORTA POTTY (A68842)
2018 GENERAC MOBILE PRODUCTS MLT6S (A67714)
2018 GENERAC...
2015 Dodge Charger Sedan (A61574)
2015 Dodge Charger...
2002 STERLING LT9500 SERIES CRANE TRUCK (A67714)
2002 STERLING...
2019 HYUNDAI V12530152-AJS 53' X 102" T/A VAN TRAILER (A59910)
2019 HYUNDAI...
