Grapple Hyd. Hook Up For Grapple On a Mahindra
   / Hyd. Hook Up For Grapple On a Mahindra #1
swampyankee
Maine
3510 HST
Can anyone tell me how to hook up the hyd. valve to run a grapple on the bucket of 3510HST Mahindra. Can I just T off the bucket valve to a valve to run the grapple? Thanks /forums/images/graemlins/confused.gif
   / Hyd. Hook Up For Grapple On a Mahindra #2
You cannot "T" off the loader lines. You will have identify the "Power Beyond" lines to the loader valve, and put a new valve that is set up for Power Beyond in series with the loader valve.
The other option is a Electric Diverter Valve, that will direct fliud flow to either the curl cuircit or the grapple. Either option will cost around $300.00-$350.00.
If you do a search on "Diverter Valve" you will find a number of posts dealing with instalation including my own I use for a snowplow and a grapple in the future. Be sure to set the "Date Range" to "All Posts", as it defaults to only one week.
   / Hyd. Hook Up For Grapple On a Mahindra #3
Doesn't the 3510hst come with rear remotes? That is the easest way .
2014 Ford Escape (A50324)
2014 Ford Escape...
1993 Ingersoll Rand 185 S/A Towable Air Compressor (A55973)
1993 Ingersoll...
20X30 ALL STEEL CARPORT (A55745)
20X30 ALL STEEL...
PALLET OF (2) HEATERS (A55745)
PALLET OF (2)...
Miller Trailblazer 250G 4,000 Watt Welder/Generator Set (A55851)
Miller Trailblazer...
2019 ALLMAND LIGHT TOWER (A55745)
2019 ALLMAND LIGHT...
