Hyd help needed
/ Hyd help needed #1
LWF
Maine
JD 1010 Gas , kubota L3830
One more time on remotes, I have a kubota L3830 with a BH90 backhoe. My hyd block on the side of tractor has 3 ports. The power beyond port goes to the back to the back hoe and loopes( either through the backhoe valve or if taken off the two connect toghether) back to the front and connects to the loader valve to the PB port. The other two hyd ports, pump and ret hook up to the loader valve. I want to hook up an aux valve. Do i disconnect the power beyond hose coming from the backhoe and going to the loader valve and connect it to the PB on the new valve and then run a hose from the PB on the loader valve to the inlet on the new valve and tee the returns together. I am a little confused with the PB going to the backhoe first. Wow got it all out.
Thanks Larry
/ Hyd help needed #2
I don't quite follow your plumbing, but suggest you search the archives. I am taking my first stab at plumbing in a valve and found the many postings by the late Mad referee quite helpful See the following for a good description I am following for my MF GC 2310. One change I am looking at is teeing the returns so I do not need to disconnect to use the Hoe.
There is a good thread on the orange tractor site site discussing how to do it on a BX
http://www.tractorbynet.com/forums/k...ear+remotes+BX
Dan
/ Hyd help needed #3
Dan
What do you mean "late" Mad Referee??
/ Hyd help needed #4
I'm so sorry...
I just read the news in one of the forums at the bottom..
Very sad news. I've been waiting for him to appear and help me with hydraulics..
My deepest sympathies to his family, friends and everyone on TBN who came in contact with him.
