Hyd Filter change
/ Hyd Filter change #1
sod buster
ford 1710
I have both a repair manual and a parts manual for my model 1710 Ford Tractor 1986. There is no information about changing the hydraulic oil filter. Looking at the old filter on the tractor, it is not a spin-on, but rather has an outside canister with a nut in the center bottom. It appears that the actual filter may be inside the canister. Can anyone shed some light on how I can change this filter, and where I can buy one? Can I change the filter without changing out all the hydraulic fluiid? Thank you.
/ Hyd Filter change #2
My car has the same kind of filter setup, when you take the nut off there is a bare filter element inside that looks like a big fuel filter. Can't help you on where to buy one, I'd do some googling.
When I change the filter on my tractor I attach a shop vac to the fill port and turn it on when I'm ready to take the filter off. That pretty much reduces the loss to almost nothing.
/ Hyd Filter change
Thanks Beezfun. I’ll give that a try as soon as I can find one.
/ Hyd Filter change #4
9846407 is the part number for your hydraulic filter. It is a spin on filter; yours happens to have a nut formed on the bottom.
New/Unused CFG Industrial H15R Mini Excavator (A65583)
New/Unused CFG...
2019 DRAGON ESP 150BBL ALUMINUM (A60736)
2019 DRAGON ESP...
New/Unused 2 Post Car Lift (A65583)
New/Unused 2 Post...
2007 Toyota Camry Sedan (A61574)
2007 Toyota Camry...
2008 Trail- Eze Tilt Triaxle, 42' Deck/10' Neck (A62679)
2008 Trail- Eze...
2018 Nissan Versa Sedan (A61574)
2018 Nissan Versa...
