Hyd Cyl for front hitch angle kit??
   / Hyd Cyl for front hitch angle kit??
Cub -- This is what I put together for an order between Surplus Center and McMaster Carr:
Surplus Center
2 in stock 1X8X0.625 DA HYD CYL SWIVEL EYES
Item # 9-7257-8
2 in stock JIC 6M TO SAE 6M 45 ELBOW
Item # 9-6802-6-6
2 in stock JIC 6M x SAE 6M SWIVEL 90 ELBOW
Item # 9-6801-6-6
1 in stock JIC 6M x JIC 6M x JIC 6M UNION TEE
Item # 9-2603-6-6-6
1 in stock JIC 6 CAP
Item # 9-304-C-6
2 in stock 1/4" X 18" JIC 6F X JIC 6F 5000 PSI HYD HOSE
Item # 921-2218
2 in stock 1/4" X 48" JIC 6F X JIC 6F 5000 PSI HYD HOSE
Item # 921-2248
1 in stock 1/4" X 24" JIC 6F X JIC 6F 5000 PSI HYD HOSE
Item # 921-2224
1 in stock 3/8" NPT QUICK COUPLER F/F S40-3
Item # 9-7381
2 in stock JIC 6M x 3/8 NPTM CONNECTOR
Item # 9-2404-6-6
___________________________________________________________________________________
McMaster Carr
Line Quantity Item
1 2 each 91259A722
Alloy Steel Shoulder Screw 1/2" Shoulder Dia, 2-1/2" L Shoulder, 3/8"-16 Thrd
2 2 each 91259A721
Alloy Steel Shoulder Screw 1/2" Shoulder Dia, 2-1/4" L Shoulder, 3/8"-16 Thrd
3 4 each 2868T104
SAE 863 Bronze Sleeve Bearing for 1/2" Shaft Diameter, 5/8" OD, 5/8" Length
4 4 each 2868T11
SAE 863 Bronze Sleeve Bearing for 1/2" Shaft Diameter, 5/8" OD, 3/4" Length
5 1 pack 93298A130
Grade F Nylon-Insert Hex Flange Locknut Znc-Pltd Steel, 3/8"-16 Thread Sz, 9/16" W, 7/16" H, packs of 50
Cost came out to $300 for everything. Not sure what Cub sold this kit for but has to be more. I'm on the road again this week, so maybe it will here by next weekend to give it a try. ---- Tom
   / Hyd Cyl for front hitch angle kit?? #22
Thanks for sourcing the McMaster Carr. I placed an order there also. Looks like a done deal. I did get a manual for the hyd angling kit as it gives directions for setting up the cylinders.
Cub,
All parts installed -- up and operating. Everything fit well, but I am probably going to shorten up the crossover hoses. At 18" each they are a little to long. I am also going to install a shutoff valve in the crossover. I want to be able to lock the hitch on center so I don't inadvertantly angle it with the snowblower attached. That long handle will destroy something if I am not more careful than forgetful. -- Tom
   / Hyd Cyl for front hitch angle kit?? #24
Glad you got it to work! I was also wondering about the issue of accidently "angling" the snowblower....might not be pretty!
You're gonna like the angling when plowing....
Have fun!
   / Hyd Cyl for front hitch angle kit?? #25
Hey great job. I'm lagging behind with too many projects. Haven't bolted mine together yet.
2015 Ford Fusion Hybrid Sedan (A56859)
2015 Ford Fusion...
WHIRLPOOL DRYER (A54757)
WHIRLPOOL DRYER...
2025 Swict 84in Bucket Skid Steer Attachment (A56857)
2025 Swict 84in...
CASE INTERNATIONAL 5140 TRACTOR (A52707)
CASE INTERNATIONAL...
Misc Office-Desk Chairs (A54816)
Misc Office-Desk...
2021 CATERPILLAR 306 CR EXCAVATOR (A52709)
2021 CATERPILLAR...
