hyd cooler hoses bulging - normal?
   / hyd cooler hoses bulging - normal? #1
mathey
Platinum Member
MD
NH TC33D
I just happened to pop the hood on my TC33D yesterday while it was running and noticed the two hydraulic cooler hoses were bulging a good bit...these are still the "older style" hoses where it's just a straight piece of hose bent in the 90 deg angle not molded, nor the kit NH supposedly has to replace these hoses.
Is this normal or is this just a sign of them getting ready to go?
   / hyd cooler hoses bulging - normal? #2
Hoses of any kind shouldn't bulge when under pressure. Yours need replacing.
I kinda figured as much....
Is the repair kit from NH the best approach or has someone come up with a better "homegrown" solution?
   / hyd cooler hoses bulging - normal? #4
if you search you will find numerous threads on this issue.
Mike
yes, i'm well aware of that
   / hyd cooler hoses bulging - normal? #6
mathey said:
Is the repair kit from NH the best approach...
Yes.
By the way, the hoses on my 25D are molded, they are not straight hoses that have been bent.
   / hyd cooler hoses bulging - normal? #7
Time to change the hoses before they break. Be glad you noticed the bulge.
ok, of course it's snowing good here now...
will the zip tie method get me by in a pinch or is it best to just not run it at all?
does this also affect the 3ph or just the FEL? steering? HST?
I'm referring to the hydraulic cooler hoses, not the radiator hoses
   / hyd cooler hoses bulging - normal? #10
Sorry my mistake. Good question. I would expect it would affect anything hydraulically controlled.
(1) HD 24ft Free Standing Corral Panel (A51573)
(1) HD 24ft Free...
2014 INTERNATIONAL PROSTAR SLEEPER (A52576)
2014 INTERNATIONAL...
New/Unused 72in Quick Attach Mower King Hydraulic Brush Cutter (A51573)
New/Unused 72in...
New Wolverine Hydraulic Shift Pallet Forks (A51573)
New Wolverine...
2020 INTERNATIONAL LT625 TANDEM AXLE SLEEPER (A52577)
2020 INTERNATIONAL...
John Deere 5090E Tractor with Loader Prep Package, 2 Rear Remotes, Warranty Until 2028 (A53472)
John Deere 5090E...
