hyd cooler hoses bulging - normal?
   / hyd cooler hoses bulging - normal? #1
mathey
Platinum Member
MD
NH TC33D
I just happened to pop the hood on my TC33D yesterday while it was running and noticed the two hydraulic cooler hoses were bulging a good bit...these are still the "older style" hoses where it's just a straight piece of hose bent in the 90 deg angle not molded, nor the kit NH supposedly has to replace these hoses.
Is this normal or is this just a sign of them getting ready to go?
   / hyd cooler hoses bulging - normal? #2
Hoses of any kind shouldn't bulge when under pressure. Yours need replacing.
I kinda figured as much....
Is the repair kit from NH the best approach or has someone come up with a better "homegrown" solution?
   / hyd cooler hoses bulging - normal? #4
if you search you will find numerous threads on this issue.
Mike
yes, i'm well aware of that
   / hyd cooler hoses bulging - normal? #6
mathey said:
Is the repair kit from NH the best approach...
Yes.
By the way, the hoses on my 25D are molded, they are not straight hoses that have been bent.
   / hyd cooler hoses bulging - normal? #7
Time to change the hoses before they break. Be glad you noticed the bulge.
ok, of course it's snowing good here now...
will the zip tie method get me by in a pinch or is it best to just not run it at all?
does this also affect the 3ph or just the FEL? steering? HST?
I'm referring to the hydraulic cooler hoses, not the radiator hoses
   / hyd cooler hoses bulging - normal? #10
Sorry my mistake. Good question. I would expect it would affect anything hydraulically controlled.
2011 Kenworth T300 Jerr-Dan 21WSRB Rollback Truck (A52377)
2011 Kenworth T300...
Kenworth Tri Axle Dump (A47384)
Kenworth Tri Axle...
Toro Workman MDX Utility Cart (A51691)
Toro Workman MDX...
2022 CATERPILLAR 259D3 SKID STEER (A51246)
2022 CATERPILLAR...
4"x8' Treated Post, 36 Piece Bundle (A52384)
4"x8' Treated...
New/Unused 48in Quick Attach Pallet Forks (A51573)
New/Unused 48in...
