hyd back blade vrs 6 way adj
/ hyd back blade vrs 6 way adj #1
tiltbed
Bronze Member
Ohio
ford 3000,case SI..Just purchased a 404 Futon (40 hp 4wd) with a koyker FEL
Does anyone have any input on the diferences between a hyd adj back blade vrs a 6 way adjustable one?..6 way would be off set...tilt and angle..I can find all kinds of 6 way manual adjustable ones....but seem to run out of luck on hyd ones.. /forums/images/graemlins/frown.gif...is it possible to install hyd cyls on a manual adjustable one?..and yes i already have 4 remote fittings..2 pressure and 2 return..It will be used for everything drive maintaince...crown and fill a tractor path on my hill side..and even to clean out a small creek that runs through my property...can`t afford a back hoe yet...lol..I have a 404..(40 hp 4wd...thanks ..Sid... /forums/images/graemlins/laugh.gif
/ hyd back blade vrs 6 way adj #2
I've got a 6 way as you term it. I don't see why hydraulic cylinders couldn't be added. Based on my usage the only manual adjustment I'd convert to hyraulic is the tilt. That's the adjustment I'd do more frequently if it was hydraulic. It doesn't look difficult, since my back blade (Bushhog) is available with optional hydraulics so the mounts are already in place.
/ hyd back blade vrs 6 way adj #3
Look at land Pride Implements they have what you are looking for.
thanks,I`ll look at Land Pride`s web page...also found a thread in customizing about converting from manual to hyd...Sid
2018 22ft. Tycorp Vector Belt VB-16H (A60352)
2018 22ft. Tycorp...
2015 KOMATSU PC170LC-10 EXCAVATOR (A62129)
2015 KOMATSU...
MacDon 963 Draper Header (A63118)
MacDon 963 Draper...
2003 International 4300 Flatbed Dump 571559 (A62613)
2003 International...
2016 PETERBILT 579 (A63569)
2016 PETERBILT 579...
DRAGON 500 BBL ACID TANK (A58214)
DRAGON 500 BBL...
