HY/TRANS
/ HY/TRANS #1
sniper_moore
What type of hy/trans fluid do most of you use and could someone tell me the capacity of the Hy/trans system of a YM2000? Thanks Ken
/ HY/TRANS #2
Any Hy/tran fluid compatible with the JD 303 standard. I use John Deere fluids cause JD used Yanmar engines and I figuere the stuff they recomend for their engines would work in mine. I have been thinking about synthetic hy/tran fluid like Amsoil. It sounds like it would improve winter powershift performance.
Chris
/ HY/TRANS #3
I started a thread with little response about this. I have seen Tf300 spec on some tractors and TF 500 on others. I still would like to know if JD 303 will replace both or if there is two different types. My YM1820 with powersteering whines since I put the new JD303 fluid in it.
/ HY/TRANS #4
Reed, if you just changed the fluid, you may have air in the system and need to bleed it. On a car you would jack up the front wheels,and, engine off, turn the wheels back and forth several times, without bottoming, to purge the air. I imagine a tractor is similar.
Norm
/ HY/TRANS #6
I assume it is stock. It is totally contained in the steering box,(no external cylinder). There is only a block under the hood to divert flow from the pump. It uses the same pump as the lift. I have seen a Mitsubishi with a unit like this.
Forklift Safety Basket (A61567)
Forklift Safety...
FUTURE SZYMJ HYD MINI STUMP GRINDER (A62130)
FUTURE SZYMJ HYD...
Gooseneck Stock Trailer (A64047)
Gooseneck Stock...
2010 Acura MDX AWD SUV (A61569)
2010 Acura MDX AWD...
New/Unused Landhonor 20,000lb Electric Winch (A61166)
New/Unused...
New/Unused 3 Point Hitch (A61166)
New/Unused 3 Point...
