HVAC wiring and breakers
   / HVAC wiring and breakers #1
czechsonofagun
Elite Member
Old Dominion
Kubota B1750
I am reading up on my future project and here is a question on wires. This is what I can understand from resources I found:
Air handler - 240V, double breaker - provides power to the blower and circuit boards (2+1 romex, based on the current, #10 should be enough)
Emergency heat strip - 240V, double breaker - separate wire and breaker - provides power to the heating element (2+1 romex, sized by the heating element, #6 for 10KW)
Heat pump - 240 V, double breaker - provides power to the whole heat pump (2+1 romex #8)
The signal wiring (18gauge, 6 or more strand wire) goes from heat pump to air handler and from air handler to the thermostat.
Do I understand it correctly? Or is there a need for a 0 wire for the air handler? I have the space on my panel, but technically I could have a subpanel next to the air handler and distribute the power from there.
   / HVAC wiring and breakers #2
Different political entities have different electrical codes. Down here, 3+1 romex is required for 240 volts. I do not know what you mean by 0 wire.
Oops. that's czechism. We call minus wire 0 - say in electrical outlet you have the phase (+) and 0 (-). Sorry :)
Anyway, up here we distinguish 240V with and without negative - water heater is connected by 2+1 (two power wires and ground) but electrical stove has 3+1 (two power wires, negative and ground - since it needs 120V for the display and owen lights)
   / HVAC wiring and breakers #4
Whats the amp draw?
   / HVAC wiring and breakers #5
Normally if it says 240V, it's 2w+gnd. 240/120V is 3w+gnd. Put in what the manual for the AH says. The 3rd wire is neutral, not a negative.
2004 Freightliner FL60 Ambulance (A56858)
2004 Freightliner...
2022 Horizon Trailer (A55973)
2022 Horizon...
2018 Ford F-150 4x4 Crew Cab Pickup Truck (A56858)
2018 Ford F-150...
Kubota BX2680 Sub-Compact Tractor  4WD, 218 Hours (A55301)
Kubota BX2680...
2023 HarbinGer V3 Plus 8KW S/A Towable Light Tower (A55973)
2023 HarbinGer V3...
2019 Ford F-350 4x4 Flatbed Truck (A55788)
2019 Ford F-350...
