HVAC wiring and breakers
   / HVAC wiring and breakers #1
czechsonofagun
Elite Member
Old Dominion
Kubota B1750
I am reading up on my future project and here is a question on wires. This is what I can understand from resources I found:
Air handler - 240V, double breaker - provides power to the blower and circuit boards (2+1 romex, based on the current, #10 should be enough)
Emergency heat strip - 240V, double breaker - separate wire and breaker - provides power to the heating element (2+1 romex, sized by the heating element, #6 for 10KW)
Heat pump - 240 V, double breaker - provides power to the whole heat pump (2+1 romex #8)
The signal wiring (18gauge, 6 or more strand wire) goes from heat pump to air handler and from air handler to the thermostat.
Do I understand it correctly? Or is there a need for a 0 wire for the air handler? I have the space on my panel, but technically I could have a subpanel next to the air handler and distribute the power from there.
   / HVAC wiring and breakers #2
Different political entities have different electrical codes. Down here, 3+1 romex is required for 240 volts. I do not know what you mean by 0 wire.
Oops. that's czechism. We call minus wire 0 - say in electrical outlet you have the phase (+) and 0 (-). Sorry :)
Anyway, up here we distinguish 240V with and without negative - water heater is connected by 2+1 (two power wires and ground) but electrical stove has 3+1 (two power wires, negative and ground - since it needs 120V for the display and owen lights)
   / HVAC wiring and breakers #4
Whats the amp draw?
   / HVAC wiring and breakers #5
Normally if it says 240V, it's 2w+gnd. 240/120V is 3w+gnd. Put in what the manual for the AH says. The 3rd wire is neutral, not a negative.
2014 Freightliner MT55 Step Van (A56858)
2014 Freightliner...
2008 JOHN DEERE 310SJ BACKHOE (A52709)
2008 JOHN DEERE...
2007 International 4300 (A53314)
2007 International...
2019 GALYEAN EQUIPMENT CO. 150BBL STEEL (A58214)
2019 GALYEAN...
2007 FORD F-450 SUPER DUTY (A58214)
2007 FORD F-450...
2017 FREIGHTLINER CORONADO SD122 DAY CAB (A56138)
2017 FREIGHTLINER...
