Husqvarna LTH130
   / Husqvarna LTH130 #1
window
Ashland, WI
NH TV145/2005
I did a YouTube fix on the fuel solenoid (basically taking it out of the loop)
and the engine now starts and runs fine. BUT, and I gotta believe it's related,
when I take the brake off the engine quits. Is there some circuit that needs
to be reconnected to the solenoid? I'm no electrical whiz. Thanks.
   / Husqvarna LTH130 #2
I would be leaning more toward loosing spark due to the seat switch not detecting somebody in the seat.
   / Husqvarna LTH130
I'm leaning toward the brake switch but need to find my multimeter to check continuity. It doesn't look like a
just snap in and out piece so I want to check it first. Fortunately, no big snow predicted.
   / Husqvarna LTH130 #4
While holding the brake down engage the pto and see if it keeps running or dies.
   / Husqvarna LTH130 #6
Releasing the brake or engaging the pto and having the engine die most of the time is due to a problem with the seat switch.
   / Husqvarna LTH130
I'll see about getting a new one.
   / Husqvarna LTH130 #9
You can disable for testing but is wise to put it back in for actual safety use. Be aware that some switched are always open and others are always closed, and some have both in the same switch. Also on some you cannot just unplug the switch since some of the wiring harnesses have self shorting plugs built into the connector.
   / Husqvarna LTH130
All 3 switches associated with this have been replaced. Same thing happens: let off the parking brake, it dies. Pull the PTO, it dies.
I have a multimeter - where do I start? I checked whatever I could for electrical connections and don't find any obvious connectors
not connected.
2013 Doyle Dry Fertilizer Tender Trailer - Kubota Diesel, 3 Stainless Compartments, Side Discharge (A53472)
2013 Doyle Dry...
2012 Dodge Grand Caravan Van (A51694)
2012 Dodge Grand...
Pallet of (6) 8 Lug Misc Wheels (A51573)
Pallet of (6) 8...
2015 Crane Carrier Co. Low Entry T/A New Way Side Loader Garbage Truck (A51692)
2015 Crane Carrier...
New/Unused 48in Quick Attach Pallet Forks (A51573)
New/Unused 48in...
7021 (A50322)
7021 (A50322)
