Husqvarna LTH130
   / Husqvarna LTH130 #1
window
Ashland, WI
NH TV145/2005
I did a YouTube fix on the fuel solenoid (basically taking it out of the loop)
and the engine now starts and runs fine. BUT, and I gotta believe it's related,
when I take the brake off the engine quits. Is there some circuit that needs
to be reconnected to the solenoid? I'm no electrical whiz. Thanks.
   / Husqvarna LTH130 #2
I would be leaning more toward loosing spark due to the seat switch not detecting somebody in the seat.
   / Husqvarna LTH130
I'm leaning toward the brake switch but need to find my multimeter to check continuity. It doesn't look like a
just snap in and out piece so I want to check it first. Fortunately, no big snow predicted.
   / Husqvarna LTH130 #4
While holding the brake down engage the pto and see if it keeps running or dies.
   / Husqvarna LTH130 #6
Releasing the brake or engaging the pto and having the engine die most of the time is due to a problem with the seat switch.
   / Husqvarna LTH130
I'll see about getting a new one.
   / Husqvarna LTH130 #9
You can disable for testing but is wise to put it back in for actual safety use. Be aware that some switched are always open and others are always closed, and some have both in the same switch. Also on some you cannot just unplug the switch since some of the wiring harnesses have self shorting plugs built into the connector.
   / Husqvarna LTH130
All 3 switches associated with this have been replaced. Same thing happens: let off the parking brake, it dies. Pull the PTO, it dies.
I have a multimeter - where do I start? I checked whatever I could for electrical connections and don't find any obvious connectors
not connected.
2025 New/Unused Wolverine 72in Skid Steer Hydraulic Rotary Tiller (A51573)
2025 New/Unused...
BUSH WACKER ST-180 ELITE BATWING ROTARY MOWER (A51406)
BUSH WACKER ST-180...
2022 McConnel TRAXX RC28 43in. Remote Controlled Slope Mower (A51691)
2022 McConnel...
(1) HD 27ft x 24ft Full Garage Kit Metal Building Frame (A51573)
(1) HD 27ft x 24ft...
2015 Ford Escape SUV (A50324)
2015 Ford Escape...
2018 John Deere 310L 4x4 Extendahoe Loader Backhoe (A52377)
2018 John Deere...
