Husqvarna LGT2454 - drive belt not tight (missing spring?)
   / Husqvarna LGT2454 - drive belt not tight (missing spring?) #1
jpilk99
Bolton, MA
1983 Ford 1700, 4WD, 770 Loader, Woods backhoe, Woods brush hog,etc.
Hi all,
I have a Husqy 960450007 01 and the drive belt is quite loose. Maybe the belt is stretched but ...it barely drives.
Noticing on parts diagram that there is a Return Spring listed (#161 below) but I'll be dammed if I can see this under my machine. Can anyone comment if they have one of these return springs under their machine - and where it connects? This graphic seems to suggest there is a little hole to the far right of that black brake bar (just above the #211 image below) that might anchor the forward part of the spring while the other end would go through a hole on the side of the frame?? But again, I ain't got a spring under mine.
Thanks for any help.
Jay
Disregard; I figured it out. I need that #161 spring. Thanks all
   / Husqvarna LGT2454 - drive belt not tight (missing spring?) #4
I don’t see part # 161 on the picture you posted. Can you post where said spring # 161 goes?
3-Point Hitch Root Grubber - Heavy-Duty Tree and Stump Puller for Tractors (A53473)
3-Point Hitch Root...
2018 KENWORTH T880 DAYCAB (A53843)
2018 KENWORTH T880...
2021 JOHN DEERE 648LB SKIDDER (A51406)
2021 JOHN DEERE...
2009 Ford F-350 4x4 Flatbed Truck (A51692)
2009 Ford F-350...
