Husqvarna LGT2454 - drive belt not tight (missing spring?)
/ Husqvarna LGT2454 - drive belt not tight (missing spring?) #1
jpilk99
Gold Member
Bolton, MA
1983 Ford 1700, 4WD, 770 Loader, Woods backhoe, Woods brush hog,etc.
Hi all,
I have a Husqy 960450007 01 and the drive belt is quite loose. Maybe the belt is stretched but ...it barely drives.
Noticing on parts diagram that there is a Return Spring listed (#161 below) but I'll be dammed if I can see this under my machine. Can anyone comment if they have one of these return springs under their machine - and where it connects? This graphic seems to suggest there is a little hole to the far right of that black brake bar (just above the #211 image below) that might anchor the forward part of the spring while the other end would go through a hole on the side of the frame?? But again, I ain't got a spring under mine.
Thanks for any help.
Jay
Disregard; I figured it out. I need that #161 spring. Thanks all
/ Husqvarna LGT2454 - drive belt not tight (missing spring?) #4
I don’t see part # 161 on the picture you posted. Can you post where said spring # 161 goes?
UNUSED IRANCH MINI EXCAVATOR QUICK COUPLER (A60432)
UNUSED IRANCH MINI...
Truck Mounted Carpet Cleaning Extraction Machine (A57454)
Truck Mounted...
PALLET OF 15 4X8 GROUND PROTECTION MATS (A58214)
PALLET OF 15 4X8...
2018 Freightliner M2 106 Cab and Chassis Truck (A59230)
2018 Freightliner...
2012 MACK Tender Truck w/ADAMS Rear Discharge Bed Auger (A61307)
2012 MACK Tender...
2008 TCE MANUFACTURING 20GN GOOSENECK GEN TRAILER (A58214)
2008 TCE...
