Husqvarna 48" blower kit for lawn tractor not mulching leaves
   / Husqvarna 48" blower kit for lawn tractor not mulching leaves #1
86celtics
Hi,
Had my lawn tractor (YTH24V48LS) for two years and has worked great (better than I thought it would, actually). Always good on grass, great in the fall. I have a 48" Blower kit (OEM p/n 966529102) for the grass catcher which, normally, vacuums the lawn like a Hoover and mulches the leaves like a Cuisinart (works well).
Today, the vacuum part works as usual but I noticed that the leaves are being picked up and sent to the grass catcher without being shredded at all. Full leaves as if I raked them and put them in myself. The only thing that has changed is that I replaced the drive belt (OEM p/n 539 130347) with a spare I had lying around this morning.
I have to assume it has nothing to do with the belt because the vacuum function is working perfectly.
I know that dull mower blades can have an impact on the mulching quality but can they work great one day and not at all the next? I don't think so...
Any input would be appreciated.
   / Husqvarna 48" blower kit for lawn tractor not mulching leaves #2
Hi,
Do you have mulch blades on the deck or the regular blades? Regular blades will send it directly to the bin I think. Also-where can I get info on the OEM vacuum?
Never mind-lloks lit it wont work on a 2006.
I have mulch blades that are designed for lift.
   / Husqvarna 48" blower kit for lawn tractor not mulching leaves #4
Could be dull blades along with a slower than designed rpm because of the belt?
I never thought of the belt. I'll check it out, thanks.
Pitts Tri-Axle RGN Lowboy Equipment Trailer (A50322)
Pitts Tri-Axle RGN...
EVERYTHING SOLD AS-IS WHERE IS!! (A50775)
EVERYTHING SOLD...
Case Maxxum 140 (A50120)
Case Maxxum 140...
2002 JOHN DEERE 450H CRAWLER DOZER (A51406)
2002 JOHN DEERE...
JOHN DEERE 608C LOT NUMBER 19 (A53084)
JOHN DEERE 608C...
Gravely Pro-Turn 460 60in Zero Turn Commercial Mower (A52377)
Gravely Pro-Turn...
