Husqvarna 48" blower kit for lawn tractor not mulching leaves
   / Husqvarna 48" blower kit for lawn tractor not mulching leaves #1
86celtics
Hi,
Had my lawn tractor (YTH24V48LS) for two years and has worked great (better than I thought it would, actually). Always good on grass, great in the fall. I have a 48" Blower kit (OEM p/n 966529102) for the grass catcher which, normally, vacuums the lawn like a Hoover and mulches the leaves like a Cuisinart (works well).
Today, the vacuum part works as usual but I noticed that the leaves are being picked up and sent to the grass catcher without being shredded at all. Full leaves as if I raked them and put them in myself. The only thing that has changed is that I replaced the drive belt (OEM p/n 539 130347) with a spare I had lying around this morning.
I have to assume it has nothing to do with the belt because the vacuum function is working perfectly.
I know that dull mower blades can have an impact on the mulching quality but can they work great one day and not at all the next? I don't think so...
Any input would be appreciated.
   / Husqvarna 48" blower kit for lawn tractor not mulching leaves #2
Hi,
Do you have mulch blades on the deck or the regular blades? Regular blades will send it directly to the bin I think. Also-where can I get info on the OEM vacuum?
Never mind-lloks lit it wont work on a 2006.
I have mulch blades that are designed for lift.
   / Husqvarna 48" blower kit for lawn tractor not mulching leaves #4
Could be dull blades along with a slower than designed rpm because of the belt?
I never thought of the belt. I'll check it out, thanks.
1065 (A53342)
1065 (A53342)
TORO MBTX 2500 STAND-ON CONCRETE BUGGY (A51406)
TORO MBTX 2500...
2010 Turfco Mete-R-Matic III Pull-Behind Top Dresser (A54811)
2010 Turfco...
2018 John Deere 1653 (A55302)
2018 John Deere...
Utility Trailer (A52377)
Utility Trailer...
2018 Ford F-250 Reading Enclosed Service Truck (A53422)
2018 Ford F-250...
