Husquavarna Used Pro Saw
/ Husquavarna Used Pro Saw #1
johnnydel29
Bronze Member
East of Albany, NY
JD 2305
I having my property logged. The Logger mentioned to me that they run thier chainsaws for 1 year and buy brand new ones and sell the 1 year used ones. I am thinking about buying one, my question is, is it worth it?
The saw is a Husky 575XP professional. I cut wood, but not everyday like these guys do. When I do, a few times a month, I cut a lot. I am thinking I would love the HP and reliability of this saw, however, would it be worth buying used for $300.00?? Or, should I just spend an extra $75.00 and get a brand new mid range saw (Husky Rancher).
If there are any loggers out there, I would love to hear your opinion.
/ Husquavarna Used Pro Saw #2
Here is a comparison of the two. Notice the difference in HP and recommended bar length. Husqvarna Outdoor Power Equipment -
I called my local saw shop and they get $749-$799 for the 575 XP (new). And they have some used ones for $500.00 (gone over)
Sounds like a good deal to me.
Chris
/ Husquavarna Used Pro Saw #3
Have you considered the weight of the saw and what you will be using it for? :D :D
Chris
Chris, thanks so much for your feedback. Wow!! that saw goes for that much!! Since I will only be using it to cut up big hardwoods, higher HP is definitely better. I am currently using an older Stilh MS 025, nice little saw, but it is on the verge of getting killed since I started cutting larger hardwood. I definitely need something w/ more hp. I think the Rancher will be fine, even though he says they are used for one year, unless your a pro logger, I will never know how really use the saw is.
I guess 300 bucks is a good deal, however, remeber, he is logging our land and he will probably make it up elseware, if you know what I mean.
/ Husquavarna Used Pro Saw #5
like egon said, too big a saw is no bargain. I don't have enough info on your use to say, but I'm guessing the Rancher is more than enough, and the pro saw would have you hating life.
I usually cut around 6-10 60' oaks a month. Rancher was too big a saw for me (though I could see getting one) 350 with 18" bar is just fine, and a lot more fun to hold for a day.
That 575 weighs 15 pounds. That's my only objection to it as a saw, but it's a heavy objection! Try holding 15 pounds out at arms length for a few hours.
If you are regularly cutting up 24" trees, that's a different issue
/ Husquavarna Used Pro Saw #6
I would also agree that a 575 is a BIG saw...I'm a professional logger and I typically use a Sthil MS 361 pro saw for 95% of the work I do. I do have a Stihl MS 440 that i use only as a back up or for big hardwoods...
but if you like the size, its a pretty good deal provided its a good running saw...
-TMTS
/ Husquavarna Used Pro Saw #7
When comparing the two saws that he is considering, the 575 only weighs 2 pounds more. Of course, 15# is a lot, but wouldn't be bad if you had another saw to limb with.
Chris
/ Husquavarna Used Pro Saw #8
I have a 570 with a 18 inch bar and wish I had the 575 for the extra power. They are both 14.9 pounds. It's my most used saw, I use it all day, no problem. I have a 385xp with a 28 inch bar for the bigger stuff, it seems to be a good combination.
That sounds like a good deal.
/ Husquavarna Used Pro Saw #9
If you plan to keep your stihl for lighter jobs and the Huskvarna for the big logs it sound like a nice match. Most of my work is under 12 inches so my Husky 353 with the 18 inch blade is perfect. One thing I don't like about the rancheris it's made in south america (Argentina) not Sweden. Not sure if it makes any difference at all but I just always felt Sweden had a good reputation for buiding good machines.
/ Husquavarna Used Pro Saw #10
The 455 Rancher is an overpriced overweight weak saw IMO, if you want a decent new saw look at the Husky 359 instead. The 575 is powerful but heavy. Not a big deal for bucking logs on the ground, but for anything else the weight adds up.
The 372XP is a much better saw than the 575, same power, 2# less. About $700.
You can get a used 372XP for about $400
/ Husquavarna Used Pro Saw #11
As mentioned the 372 is a much better saw. The 575 replaced the 372 with the addition of higher emission standards and higher weight. I know that doesnt help you much with the offer before you BUT....if you need a bigger saw try to find a used 372 (some places acctually still have new ones in stock as they were a VERY popular saw, parts will be available for a LONG time).
Also I have been sent out as a faller on a few wildland fire assignments. I worked close with the Professional fallers because I like to learn all the things they are willing to teach me. One of the things they mentioned is NEVER buy a used saw from a faller. Of course the guy at your place may take perfect care of and never abuse his saw.
Hutch
/ Husquavarna Used Pro Saw #12
My own take on this is there is a reason why they sell their saws after one year.
Probably they have found through experience that they are worn out somewhere around there.
Small portable engines just don't last that well. They are designed for a very high power to weight ratio, which means that durability is sacrificed.
I would go with a new mid-range saw, which will last for a good long time under the use you will give it.
