Husky Rancher 50 1984 model Bar Oil Leak
   / Husky Rancher 50 1984 model Bar Oil Leak #1
Val Padana
Australia
Valpadana
My trusty 1984 Husky Rancher 50 sprung a bar oil leak. I shoved some plastic tubing into the hole above the filler which "fixed" the leak well enough to enable the saw to be used but hopefully it can be fixed properly. What was in that hole? Any chance I can find a replacement, maybe even something from a later model?
Although rather weighty it is a great saw, plenty of power.
TIA
   / Husky Rancher 50 1984 model Bar Oil Leak #2
I had one see if old pics shows anything.
Can see something. Checking IPL
Per IPL tank valve plug and star retainer.
   / Husky Rancher 50 1984 model Bar Oil Leak #3
Early Husqvarna 50 IPL for ya to download. Has part numbers.
  • IPL-50-Rancher-1983_I8400014.pdf
   / Husky Rancher 50 1984 model Bar Oil Leak #4
I have a way back background in Computer Science. IPL to me means Initial Program Load or Boot Loader in current terminology. What's your "IPL"? 🤷‍♂️
   / Husky Rancher 50 1984 model Bar Oil Leak #6
Thanks. :ROFLMAO:
   / Husky Rancher 50 1984 model Bar Oil Leak #7
And it looks like the spring clip and the valve are NLA from Husqvarna.
Thank you for your helpful replies and the IPL xyz, and your white top Rancher 50 is identical to mine.
There's very few long established Husky dealers around my way who might have dusty shelves of 40 year old parts, or could be bothered to look for them, but worth a try now I know the part numbers.
Otherwise shouldn't be too hard to cobble something up. I very seldom fell any trees, mostly cut up fallen stuff for firewood so the saw isn't being run on it's side. As I mentioned jamming the plastic tube into the hole works kind of OK.
   / Husky Rancher 50 1984 model Bar Oil Leak #10
You might try chainsawr.com for used chainsaw parts, if the parts you need are no longer in production. I’ve had good luck finding parts to fix some older saws from them.
2023 54' Hooklift Dumpster 20 Cubic Yard (A55788)
2023 54' Hooklift...
Biljax Indoor Scaffolding (A52377)
Biljax Indoor...
1779 (A51248)
1779 (A51248)
Behlen 150 Gallon Premium Stock Tank (A55218)
Behlen 150 Gallon...
2021 Kubota RTV-X1140RL-A (A47384)
2021 Kubota...
2017 Ford Explorer SUV (A55758)
2017 Ford Explorer...
